Thread: Engine more sluggish, mpg dropping :(
    Leicestershire
    Default Engine more sluggish, mpg dropping :(
    Hi All,
    Car - 05 Plate Vectra 1.9cdti (150).
    I would just like to know peoples thoughts on the following - basically I think my Vectra is running less perky and using more fuel following the last work done.
    1. Around August I had to have the swirl valve/manifold work done, luckily this was covered by a warranty I had
    2. Following this the car went better than before and I seemed to be getting 45mpg (2-3mpg better than before)
    3. Last week I have the 3rd cylinder wiring loom fault and got this fixed.
    4. Now, the fuel gauges seems to be falling faster than ever and the umphf seems to have gine when you boot it . My best guess is that I will only be getting 450-500 miles per tank compared to around 550 prior to the wiring loom fix.
    Based on the above info whats happened and can I do anything?
    All the work has been carried out by my local dealer (5 mins walk from my house) - expensive but convenient.
    Thanks, Markluk
    Regular Member j13hdb's Avatar
    Nottingham
    Have you had the fuel filter changed? Especially if you run on supermarket diesel. Also run it low then try a tank me shell v formula
    Leicestershire
    As a bit more background - I have been running on Tesco/ASDA fuel for as long as I can remember - due to the location/cost.
    I am a bit confused as the car was running great just prior to the wiring loom fix and now its not - do they do any mods to the engine management when they fix the wiring loom???
    As for the fuel filter - the only work that has been done on the car is what is covered in the standard Vauxhall dealer services each year (was last done in Feb 08)
    Leicestershire
    An update..............
    Well I have done a full tank and now only get 42mpg compared to the 46mpg I had before the injection wiring fix.
    The car seems to drive ok, maybe a bit more sluggish or maybe its just a smoother ride??
    The car is due for service / MOT next month so I will go full a fuller service with fuel filter replacement etc.
    Any ideas.........
    chesterfield
    any engine management light?
    maybe they disturbed something when fitting wiring loom like a vacuum pipe or somet
    Leicestershire
    Hi all,
    No there is no engine managment light....thats why I am a bit bemused by it all!
  1. vectra c 2.0 dti sluggish engine
    By Legion84 in forum Engine & Drivetrain
    Last Post: 19th July 2012, 17:37
  2. Engine vibrate, sluggish and loud
    By JonJoe in forum Engine & Drivetrain
    Last Post: 17th June 2012, 15:49
  3. engine revs dropping when cold 03 2.2DTI
    By stuartcorbitt in forum Engine & Drivetrain
    Last Post: 7th July 2011, 18:15
  4. Cdti lack of power engine sluggish
    By Diesel Dude in forum Engine & Drivetrain
    Last Post: 19th January 2011, 16:07
  5. i think im dropping to a vec B
    By carlsondavid33 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 15:10
Tags for this Thread
