Thread: Windscreen wash fluid warning won't go away!
    Apr 2008
    Northants
    Default Windscreen wash fluid warning won't go away!
    During the cold weather a couple of weeks ago, i drove around for a few days with no screen wash in the tank. The warning was on for the duration. I finally came round to filling it up, and now the warning won't go away.
    Its really annoying as it takes over the central display (the orange backlit type).
    Either:
    1. Sensor is now ******ed.
    2. It needs resetting - does anyone know how?
    Thanks.
    Full Member Big Sig's Avatar
    It could just be stuck, i am assuming its a float type thats in the tank. maybe a need to remove the wheel arch liner and have a poke about with the sensor.
    Apr 2008
    Northants
    Could be I suppose. I'll fill it right up to the top and go for a bumpy drive.
    I only put a pint in when i did fill it up.
    Regular Member poves's Avatar
    lancashire
    ^^ wat e said .
    Regular Member Vauxhall Thru & Thru's Avatar
    May 2008
    Nottingham
    Maybe the fault-code is stored into ECU memory? You could try disconnecting the battery for a while - maybe this would clear it? (I'm sure one of the guru's will correct me!)
    Regular Member Jeff Lynne's Avatar
    England
    Quote Originally Posted by Last Turkey View Post
    Pint not enough ?
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Quote Originally Posted by Jeff Lynne View Post
    Pint not enough ?
    this
    mine starts warning me way before it runs out. I carried on using it for weeks after it started moaning at me cos i wanted the garage stuff to run out. It had something in it that just smeared the screen (think it had some rain-x type thing in it) and wanted all of it gone before i added more.
    To fill it took at least 2 kettles full of water (easy way of carrying 1litre of cold water to car) plus screen wash, so i doubt a pint touched it.
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Windscreen wash reservoir 2.9 litres
    with headlight wash system 5.6 litres
  1. Windscreen wash mod help
    By mickyh7 in forum Vectra C / Signum Car Chat
    Last Post: 18th February 2013, 20:20
  2. £2 Heated windscreen wash system? (DIY)
    By Sierra2 in forum Styling
    Last Post: 1st December 2012, 10:53
  3. Windscreen washer fluid
    By Sigmacca in forum Vectra C / Signum Car Chat
    Last Post: 25th November 2011, 20:14
  4. Clearalex windscreen wash
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2009, 21:36
  5. Boot jammed and display screen warning about windscreen wipers fluid
    By Gary1985 in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2009, 12:14
