Thread: Windscreen Washers.......
    Regular Member david.aka.judas's Avatar
    Suffolk
    Default Windscreen Washers.......
    run the washer fluid bottle empty, filled it right to the top and turned the washers on and nothing came out.....!
    thought damm - blocked washers...... cleaned the jets and retried the washers.
    nothing came out......checked the bottle and only half of the fluid left.
    must have a split in the pipe - anyone else had this and how do I fix it?
    many thanks if you can help.
    Yep, find the leak and fix it! Although it may take some tracing but it doesn't go to far. Would have thought you would see that much fluid on the floor. Does the back one work ok?
    Northampton
    Engine : A20DTH
    Mileage : 88000
    If you only use water then it can freeze and split the fluid bottle/pipes. Can you hear the motor work when you try the washers?
    Any water coming out from under the car when u use the washers?
    Suffolk
    lol.......no the back one doesnt work either?
    Suffolk
    Quote Originally Posted by merikiito View Post
    never use just water its too cold in suffolk and yep - I can hear the motor working.
    You don't see any evidence of it leaking onto the floor?
    Suffolk
    i need to check the missus is here - that way I can check when she pulls the stalk.
    or I pull the stalk and she gets on the floor.............hahahaha
    Suffolk
    very strange......
    missus sits in the seat, filled the fluid back up (took 700ml) had the bonnet up, she pulled the stalk and all jets worked.
    one thing I noticed was how noisy the pump was when the cars stationary.
    oh well - I must stop running the bottle dry.
  1. Windscreen Washers
    By Bloicy in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2012, 22:42
  2. windscreen washers
    By bigsteve2255 in forum Electrical & ICE (including SatNav)
    Last Post: 7th January 2011, 23:08
  3. Windscreen Washers
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 24th December 2010, 22:04
  4. windscreen washers
    By woody in shetland in forum Vectra C / Signum Car Chat
    Last Post: 2nd May 2008, 19:04
  5. Windscreen washers
    By T4M in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2007, 23:33
