Results 1 to 10 of 30
Thread: Do you trust your local filling stations air compressor?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Do you trust your local filling stations air compressor?
    having some real problems with 3 different petrol stations air compressors where i live as they are all giving different tyre pressure readings.has anybody ese found this? ive just bought a digital pressure gauge hope this is honest,as my veccys ride is playing up at the moment.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can't say I've ever noticed.
    As long as the tyres aren't flat at the top, you'll be OK.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by bobby-tupper View Post
    If it's a digital pressure gauge, then they're very accurate according to write ups in the car press.
    EDIT - meant to say a digital hand held pressure gauge from Halfrauds or similar.
    I don't trust the gauges on garage airlines either so I bought a digital gauge which showed how much some are out! Previous consumer tests on garage airlines showed the same.
    The digital airlines where the pressure is set on the main unit are pretty good and I've found those to be pretty much correct. It's the ones with the analogue gauge on the actual hand unit that are often waaay out - usually because people chuck the thing around/drop it on the floor so it's never going to keep it's accuracy for very long.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    all the garages have those new fangled digital compressors its these that have been giving my false pressures,makes you wonder tho as id never questioned there accuracy before
    Jun 2007
    Black Country
    NEVER use the airlines on garage forecourt
    1. There calibrated once every million years
    2. They get damaged by other cars driving over them
    3. You should only check your tyres when cold, if you have to drive to the garage, your tyres will be warm.
    For the sake of spending £5 on a footpump and £5 on a decent pressure guage, its not worth risking the airlines
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I only ever use the airlines at the garage. I don't own a footpump or gauge and doubt that I ever will.
    Is there any significant difference between 30 PSI and 31 PSI, in terms of durability, MPG etc etc?? probably not.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    there is quite a difference between 30psi and 37psi it just felt like my shocks had been welded up
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI160
    Year : 2012
    I use the hand held gauge - for under a tenner it's definitely worth having I think. Otherwise, it's hit & miss with anything that joe public is using & abusing daily.
    I put air in with the forecourt compressor and then recheck with my gauge.
    Even a few psi out from what it should be isn't good.
    Yes tyres should be checked when cold, but if you are just doing a few miles at 30 mph down to the forecourt, that should be fine.
    Regular Member mooney's Avatar
    North west
    Trim : VXR
    Engine : 2.8 v6 turbo
    Year : 06
    tps ftw
  1. Petrol Stations
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2009, 17:54
  2. Tesco Petrol Stations
    By rob1964bike in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 22:06
  3. Radio Stations
    By ed taylor in forum General Chat
    Last Post: 18th November 2007, 15:21
  4. Petrol Stations
    Last Post: 13th November 2007, 21:01
  5. Action stations Action Stations
    By Brocks in forum General Chat
    Last Post: 13th September 2007, 13:50
