Results 1 to 10 of 18
Thread: Drifting to the left
    Rotherham
    Default Drifting to the left
    Hi All
    My 57 plate CDti 150 hatch is drifiting/pulling to the left. If you line the steering up dead straight, the car moves drifts to the right. I've had the front tracking done by Kwik Fit and it was only fractionally out.
    Any ideas? I bet the dealers will tell me it's a characteristic!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    If you drive down the centre of the road straddling the white line does it still pull to the left?
    Rotherham
    Yep, it seems to be regardless of camber. The steering wheel is pointing slightly to the left to maintain a true straight ahead position.
    I forgt to mention that it pulls to the left when braking too, perhaps more noticable than when not braking.
    Mar 2007
    Southport
    Try jacking up the front nearside wheel & see if the brakes are binding
    Mar 2007
    Southport
    Quote Originally Posted by FinestJammy1 View Post
    Do you mean left or right
    Rotherham
    To maintain a true straight ahead trajectory the steering wheel is pointing slightly to the left. If I let go of the steering wheel, the car will drift to the left quite quickly if I don't correct it.
    If I position the steering wheel so that it (the steering wheel) appears to be straight, i.e. lined up with the steering column housing, the car will then drift over to the right. It has enough directional change to the right that I don't actually have to move the steering wheel to change lanes on a motorway!
    When braking without your hands on the wheel I can physically see the wheel move to the left and hence move the car with it.
    Hope that explains it a bit better, thanks for your help.
    Regular Member mattolly86's Avatar
    oxfordshire
    sounds like 2 problems
    1 they havernt done your traking properly take it bk and tell them u want your steering wheel straight
    2 sounds like tyre pressures to me be sure to check them if not that check brakes for binding
    Mar 2007
    Southport
    As mattolly86 says, check your tyre pressures then road test it. If the steering is still out take it back to Kwik Fit & tell them to track it again but this time making sure the steering wheel is correctly set
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    It's been said time and time again on the forum that places like Kwik Fit only adjust the fronts - they aren't geared up with the equipment or have the expertise to do anything else.
    It's of paramount importance that the rear wheels have their geometry set correctly before the fronts are done as it's the rears that act as the reference point for the fronts.
    Yet again http://www.wheels-inmotion.co.uk/tec...lalignment.php
    Regular Member silverhairedracer's Avatar
    ESSEX
    Go to a decent Tyre depot with a 4 wheel laser checker,you will be surprised how far out it is .....I was ,might cost but worth it.
  1. Drifting
    By sol in forum Motorsport / Formula 1 etc. chat
    Last Post: 28th May 2011, 09:47
  2. VXR Drifting
    By spoons in forum Insignia car chat
    Last Post: 7th February 2011, 14:49
  3. Drifting to the right?
    By Craig1985 in forum Suspension, Wheels & Brakes
    Last Post: 28th January 2011, 13:01
  4. Drifting
    By spennny in forum The 'Off Topic' room
    Last Post: 15th January 2009, 09:27
