Thread: CD70 Navi - Sat Nav muted
    Nottinghamshire
    Default CD70 Navi - Sat Nav muted
    I recently bought a car with a CD70 Navi unit. The audio manual is missing but I have managed to work most of it out. The only problem is that the Sat Nav is muted and I can't work out how to turn the volume up. Both the CD player and radio are fine. I have looked through all of the menu's that I could find and pressed the 'announce' button but with no luck. There is a 'mute' symbol in the bottom-left of the 'main' screen and I presume that this is what I need to turn off - if only I could work out how.
    I would appreciate any help with this particular problem and also with obtaining an electronic copy of the manual while I order a paper copy. I know that Vauxhall don't put it on their website and I have downloaded the German copy that can be found elsewhere on this website, but it's very slow going. Thanks.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    Ok, from memory...
    Press NAVI.
    Press Settings
    Scroll to volume/announce (can't remember exactly).
    There should be 2 volume bars (one for satnav voice volume, the other for music volume)
    Make sure the voice volume is above 0.
    Winchester
    Found a previous post:
    http://www.vectra-c.com/forum/showpo...70&postcount=8
    The actual option is:
    1. Press Navi
    2. Press Settings
    3. scroll down to NAV ANNOUNCE
    4. Set as desired.
    Nottinghamshire
    Thanks very much for the info. I will have a go at this soon as I can and post the results.
    8 Post(s)
    Want a CD70 handbook?
    Here you go:-
    http://www.put-schelper.de/images/CD..._anleitung.pdf
    Nottinghamshire
    Default Thanks!
    I managed to get the problem solved (I think that was the only menu I hadn't found) and now also have a full copy of the manual (once I found the bit in English).
  1. CD70 Navi
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 14th September 2009, 21:17
  2. Navi CD70
    By Stephen S in forum Electrical & ICE (including SatNav)
    Last Post: 1st July 2009, 20:50
  3. CD70 Navi
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2009, 17:16
how to mute sat nav but keep music on in vauxhall signum
cd70 navi voice mute
can you turn the volume up on a vauxhall navi
cd70 navi turn off voice
sat nav voice turned off in insignia
vauxhall cd70 lost audio
volume on insignia sat nav
vauxhall insignia 62 plate sat nav volume
how to turn on navigation voice on insignia vauxhall 2011
insignia 2012 sat nav volume
how ro turn on nav volume insignia q
vauxhall insignia audio off
vauxhall zafira how to turn the sat nav volume up
vauxhall insignia sat nav voice
sat nav muted astra
how to mute sat nav on insignia
how to turn vectra c satnav off
how to unmute vectra c satnav
how do you turn the volume up on a vauxhall zafira sat nav
vauxhall insignia mute button
cd70 announcement volume
sat nav vauxhall vectra how to turn the mute off
how to turn of muteon vectra sat nav
how to mute sat nav vauxhall insignia
switch off voice on insignia sat nav
