Results 1 to 10 of 17
Thread: dtuk
    lanark
    6 Post(s)
    Year : 2017
    Default dtuk
    went a run to stanley yesterday and had andrew at dtuk fit this
    came back up through the scottish borders and all i can say is wow throttle response is so much better and it goes like stink all i need to do now is get it on a rolling road
    andrew at dtuk has set it for me not at the top level but he said he would be surprised if i was not getting at least 180+bhp
    Regular Member arkhan78's Avatar
    Nov 2007
    Leeds
    how much did this cost you?
    Should have got a "caterman" box as its a lot cheaper and offers very similar results. Although glad your happy with it
    lanark
    6 Post(s)
    Year : 2017
    Quote Originally Posted by arkhan78 View Post
    £200 which i thought was ok
    Regular Member cameraman's Avatar
    Leicester
    I'd rather pay the extra & get a decent box like this than a caterman e-bay jobbie, if fact I did, ok the rolling road results gave similar reults 190-195bhp for boxed cdti 150's but having tried both the Spider box I have fitted is much smoother than a caterman & the DTUK red box I had was brutal on full setting & 0-60 a smidge over 8seconds, in the end though I prefered the Spider.
    Quote Originally Posted by cameraman View Post
    Its all down to personal preference I guess. Personally I also think the 1.9 has enough problems without adding a box to it. They all work in the same way, raising fuel pressure, weather they be a £60 e bay one or a £200 more advanced one. Its just how they deliver it that varies.
    Leicester
    65000 miles with a box fitted over 2 years & so far exactly the same faults as 2 of my workmates with the same (but standard) car. EGR valve fault & alernator packed up. I've always said it would be a high mileage long term test
    EVERYWHERE
    EGR valves will always suffer with a box (or remap) because you're bound to get excess smoke even on part throttle compared to standard,but they can be turned 'off' or reduced.DPFs will be affected,particularly if they haven't had the software upgrades.DMFs will suffer too,clutches will slip and things like turbo's (strangely enough more-so with a remap when the boost is upped) will have a harder time.
    Would only recommend either if you have a warranty of some kind.
    Note: Today when I finally took car in for the DMF doing there was an Astra 150 (boxed) in at the same time having its exploded clutch/gearbox replaced! I believe the Astra uses an F32 gearbox (another good reason not to tune these cars),but the cause of the problems were mostly with the clutch.
    ayrshire scotland
    hi guys a have had ma crd2 for over a year fuil rail went fuil pressure sensor and altornator packed in the other day had it on RR got 188bhp and its a 150 but felt it really good allround but one o the guys had some german one on his cost £60 off e bay got same bhp and one more torque...
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    i got the same one fitted but in time i am removing it and having a remap as i want the turbo to come in at lower revs....at the moment its like nothing them BAM!!! big turbo boost then (next gear) nothing again them BAM!!! big boost again and thats the same in all gears....the remap will make it run a lot smother with the boost cutting in
  1. anybody with dtuk and dpf
    By DAVIDD88 in forum Engine & Drivetrain
    Last Post: 30th March 2012, 21:09
  2. Whats the difference between dtuk green and dtuk red?????
    By srinav in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2011, 10:04
  3. dtuk
    By DAVIDD88 in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2011, 09:11
  4. Dtuk Eco 3 and dtuk CRD-T tunning boxes
    By R2XPT in forum Parts for sale
    Last Post: 19th April 2011, 16:00
  5. dtuk box
    By williamM in forum Diesel Engine related
    Last Post: 29th June 2010, 02:36
