Results 1 to 10 of 15
Thread: fuel gauge query...
    Regular Member Harry's Avatar
    Uxbridge, London
    Default fuel gauge query...
    i'm trying to determine how many miles i'm getting out of the car now that the performance box is fitted.
    in order to do this i obviously want to run the tank into the red.
    now...my query is whether the orange refill warning light on the dash board is connected to the fuel gauge or the trip computer, because the light normally comes on when there is 31 miles showing on the trip computer
    can anyone shed some light onto this.
    thanks in advance!
    Sweden
    Its connected to the fuel gauge ...
    No need to run the tank into the red for that.
    If you dont trust the trip computer and dont want to calculate
    from it, theres other ways ...
    Regular Member Ian's Avatar
    York
    Harry, i would fill up the car, run it till nearly empty, then fill up again, but make note of how many litres it takes to fill and take note of how many miles since you filed uo the first time. then you can work pretty accuretly your miles per litre, then turn that into miles per gallon.
    Quote Originally Posted by pte
    yea do this dude !!!! its too much hastle doing what your thinking and this way is just as accurate
    Sweden
    Exactly !!
    And this way you can also check the computer ... if its mpg:s the same as you calc from this ...
    But it should be pretty close ... as the computer calc from the open times of the injectors, and should be pretty accurate.
    Uxbridge, London
    cheers for the info guys.
    it's not just the mpg that i want to check, it's how many miles i can get out of a full tank. i've only ever managed to break the 500 mile marker once since i've had the car. that was prior to fitting the performance box, i want to see if it's easier to achieve with the box on.....i doubt it though, it's just to much fun planting the right foot!!!
    thanks again for your responses.
    Uxbridge, London
    Andrew - it's not a complaint by any stretch of the imagination!!
    still can't find a damn type r on the motorway though!
    Uxbridge, London
    will do...cheers
    Regular Member MLC's Avatar
    uk
    The orange fuel light starts flashing when you're really low.
    uk
    What colour does it flash when you're high though Paul?? Blue
    I only flash blue at work. And I wouldn't know about getting high!!!
  1. Fuel Gauge
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2013, 09:40
  2. Fuel Gauge
    By don23 in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2011, 23:09
  3. rev counter/speedo/temp gauge/fuel gauge stopped working
    By bloodworm in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2009, 00:28
  4. Replies: 2
    Last Post: 15th September 2008, 23:18
  5. Temp gauge query
    By AndrewTi in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2007, 18:29
