Thread: CDC40 Upgrade
    N.Ireland
    confused CDC40 Upgrade
    Had my 07 sri for couple of weeks now, bought a cdc40 unit, screen and dab aerial from local breakers today. Installed unit and all working fine apart from dab stations, it just brings up dab box fault! From reading other threads I seem to be missing this dab unit, when I asked the breaker who has the complete car he said he didn't know what this was or where it is fitted. Anyone know where exactly this box is fitted and if i get it will it just plug in and dab will work? Also can cdc40 play mp3 discs? The unit came from a 07 Elegance. First post here so any help would be good!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The dab box is fitted under the glove box,top left corner. You will need the aerial cable and wiring harness as well if you have not already got it in your current car. Its a small box about 6" by 4" by 1.5" and u will need the bracket it is attached to.
    The aerial lead goes all the way to the aerial and is in two parts, first part from dab box to right hand side of the drivers footwell and then from there to the aerial. Best thing is to remove the dash and take the complete harness then you can strip out the wires u need.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    As regards MP3's just put a disk in and see if they play. There is a mp3 symbol somewhere in the GUID. It is only the later versions that will play MP3's so you might be lucky
    Regular Member fenderguitar's Avatar
    Portadown Co. Armagh N. Ireland
    Also can cdc40 play mp3 discs? The unit came from a 07 Elegance. First post here so any help would be good![/quote]
    Best of luck with the install.I have the same radio on a june 2007 exclusive,mine does not play mp3
    N.Ireland
    Thanks for the quick response! I'll ring the breaker tomorrow and get him to strip out the loom and box, prob not get up to lift it untill Sat now though as back at work tomorrow! Merikiito, may need some installation advice when i get the rest of the parts if thats o.k!
    Nice to see some people from N.I on here Fenderguitar! I'll just try a mp3 disc in mine and hope for the best!
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by snod View Post
    Not a problem, I am over in Dungannon at Xmas so if need a hand
    Nice to see some people from N.I on here Fenderguitar! I'll just try a mp3 disc in mine and hope for the best![/quote]
    Check out the N.ireland section for meets and photos etc
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    ...and presumably the DAB aerial itself?
    north west
    also first poster, was going to ask exactly the same question
    i have the head unit, aerial, dab unitm screen but no harness, aerial lead or bracket!
    i have tried ringing vauxhall up and they were useless - booked it in at mpg to check.
    does anybody know the part numbers i would need or a suitable breaker?
    thanks for any help.......
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. CDC40 to CDC40 MP3 upgrade.... any advice?
    By eamond in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2012, 08:02
  3. CDC40 DAB upgrade & I have some Q's...
    By Neve'o in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 16:46
  4. CD30 to CDC40 Upgrade?
    By DuncanM2009 in forum Electrical & ICE (including SatNav)
    Last Post: 29th May 2011, 21:33
  5. Upgrade from cdc40 to cd70
    By jhinchy in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2011, 09:09
cdc40 missing car symbol
