Results 1 to 10 of 17
Thread: Purpose of CIM
    Regular Member old cruiser's Avatar
    slough
    Default Purpose of CIM
    As you may have seen from this previous thread of mine http://www.vectra-c.com/forum/showthread.php?t=64352 regarding CIM adjustment due to mis-aligned steering cowels, been thinking , hopefully shouldn't need Tech2 as I've only made a slight adjustment?
    and secondly , what is the actual purpose of the CIM , I gather it's the steering angle sensor that looks at the postion of the steering wheel/CIM , but what happens then exactly? does it get sent to steering pump? or have I got this all wrong?
    Cheers Pete
    Surrey
    I would like to know this too as my steering still doesn't feel right.
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Interesting question, I too would like to know this.
    slough
    Quote Originally Posted by steve1975l View Post
    What's wrong with yours mate?
    Cheers Pete
    Surrey
    Tramlines and pulls slightly to the right some of which I put down to the NCT tyres.
    Belfast
    Tramlining has f**k all to do with the CIM.
    The CIM is the box of electronics that runs the dashboard computers, all the electronics inside the car, including the steering wheel position sensor (which ties back to ESP and AFL if you have them, and works the electronic indicators). The CIM also controls the immobiliser. On Astras it's a common fault with the CIM when the immobiliser loses sync with the key's chip leaving you stranded in a car that won't start.
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    its also has a squib in it to alow the horn airbag ect to join to the steering wheel it also recives the central door locking signal and its where that bong noise comes from
    slough
    Steve1975l; Sounds to me like you need a trip out to WIM, www.wheels-inmotion.co.uk and have your geometry setup including camber, well worth a visit and at the same time Tony there can check for any other underlying suspension issues.
    Cheers Pete
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    The CIM needs to be perfectly aligned mate, if you've moved it, it'll be making wrong calculations with the ABS, ESP/TC systems.
    slough
    It's more aligned than it was before mate, it was well on the wonk as it were
    Cheers Pete
  1. Clever members, whats it called n purpose??
    By SlowCoach in forum Bodywork & Interior
    Last Post: 3rd December 2012, 20:28
  2. The purpose of rear fog lights is to . . .
    By Ste in forum General Chat
    Last Post: 28th January 2009, 21:52
