Thread: Problem after fitting Box to cdti
    Regular Member PeteRs's Avatar
    here or there
    Default Problem after fitting Box to cdti
    hi i put a caterman onto sons cdti the spanner light came on it was fitted correctly now the spanner light wont go out & it wont rev at all wots up with it thanks
    Regular Member Lump's Avatar
    coventry
    at the end of the plug there is a small yellow U shaped clip remove that and plug back in. try that i had the same problem
    here or there
    ok ty
    here or there
    nope still not working & traction control light on aswell
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Have you tried turning the connector that's on the common rail round.
    here or there
    thanks pricey
    here or there
    how stupid i thought you could only fit plug 1 way any how it works too well his car now keeps up with me
    Regular Member cheekylemon's Avatar
    Aug 2007
    Droitwich - Worcestershire
    I had the same issues when fitting it to mine. Worked in the end though, just kept changing the plug around until I got the right config!
  1. HID's fitting problem
    By Smudger34 in forum Styling
    Last Post: 11th June 2012, 12:57
  2. Problem fitting tuning box
    By 2.2 oil burner in forum Diesel Engine related
    Last Post: 5th December 2010, 20:15
  3. Problem Fitting HID Bulbs??
    By bonneyboy in forum Electrical & ICE (including SatNav)
    Last Post: 16th July 2010, 13:02
  4. Problem retro fitting CDC 40 and Dab box...
    By merikiito in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 16:49
  5. Urgent help required - H.I.D fitting problem
    By Kev_A in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2007, 10:29
