Thread: 06 sri head unit upgrade ?
    Regular Member DARREN R's Avatar
    Jan 2008
    WASHINGTON
    Vehicle : vectra
    Trim : sri xp
    Engine : z19dth
    Mileage : 93000
    Default 06 sri head unit upgrade ?
    how do i get round the problem of the clock updating itself ? or is that not possible and does changing the headunit and running an amp have any probs with the canbus ?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    You'll either have to plug the original HU back in or buy a CanBus adaptor to connect the steering wheels controls back up.
    Not sure an adaptor will work.
    I have just done my 07, and will need to connect the original twice a year to change the clock (Daylight Saving!!)
    Mar 2007
    Southport
    I have a full CanBus adaptor & I can update the clock with it. Going from memory I hold down the left lower steering wheel button to access the settings menu & make the changes using the right up/down & roller buttons (menu change & settings)
    Belfast
    My stereo has an RDS clock on it. Problem solved.
    Mar 2007
    Southport
    Quote Originally Posted by _ZS_ View Post
    Unless there is a suitable interface the RDS clock on an aftermarket radio doesn't update the dashboard clock, so it will still need to be set
    Belfast
    Or you could ignore the wrong dash clock and use the correct one on the stereo....
  1. Which head unit ?
    By Mike1975 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 10:38
  2. new head unit
    By tonci26 in forum Electrical & ICE (including SatNav)
    Last Post: 23rd February 2012, 21:00
  3. head unit upgrade
    By ttjemsland in forum Electrical & ICE (including SatNav)
    Last Post: 1st October 2011, 10:01
  4. new head unit
    By bigron1988 in forum ICE Gallery
    Last Post: 4th April 2009, 18:30
