Thread: Is it mechanical or what? any tips much appreciated
    Feb 2007
    Wales
    Default Is it mechanical or what? any tips much appreciated
    Have a Design CDTI 120 5 Door Vectra new shape -2006 model year
    At 60 mph on any road surface in any weather conditions a strange - well flat sounding high pitched sound starts and is there from 60 mph onwards - but nothing under 60 mph. It kicks in exactly at 60 mph
    Have checked the following -
    1. Tyres - replaced all 4 tyres due to natural wear - now shod with Bridgestone ER30 as the car did have Goodyear Excellance on it
    2. Checked all door and hatch seals ( rear drivers door aperture seal was replaced as loose at the top )- all have also been lubricated
    3. New Pads and discs on rear under warranty - Network Q - brakes work fine and the sound is not that made when the brakes need copper grease
    4. Underside of car checked by myself and dealer and no items found with a problem
    5. Aerial checked and compared - it has the new update Vaux aerial with the wire rap
    6. Handbreak Cable was found to be loose when the upgrade on the handbrake was carried out - this was secured as it was tapping the fuel tank
    7. Rear Wheel bearings checked
    (also no ghosts etc in back of car .....)
    Any thoughts Vectra C as the sound strangly is not noticable from the drivers seat but only from the rear seats or the front passenger seat - but it is for passengers very annoying
    Otherwise car drives very well 50 mpg no problem and the DAB Radio is great
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    If you drop the clutch at said 60mph, I guess the noise is still there, so not gearbox related.
    The noise can be heard from the f/n/s passenger seat - front wheel bearings? Have you sat in the front passenger seat or back seats and tried to work out exactly where the noise is eminating from?
    Drop each of the windows in turn at 60mph (about 1/8") and check for noise.
    Any play in the doors when they're closed? Can you push them further in against the seals when parked up? Could be the door striker/s need adjusting.
    What you've got could be aerodynamic or mechanical, hard to tell without someone hearing it.
    Is the car standard in every single way?
    I'm clutching at straws here but hope it's of use.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    As it's under warranty it might be worth speaking to your local, friendly dealer.
    Feb 2007
    Wales
    If you drop the clutch at said 60mph, I guess the noise is still there, so not gearbox related. - WILL TRY THIS TOMORROW
    The noise can be heard from the f/n/s passenger seat - front wheel bearings? Have you sat in the front passenger seat or back seats and tried to work out exactly where the noise is eminating from? - I THINK ITS COMING FROM THE REAR
    Any play in the doors when they're closed? Can you push them further in against the seals when parked up? Could be the door striker/s need adjusting. - NOPE DOORS ARE FINE
    Is the car standard in every single way? TOTALLY STANDARD - I THOUGHT IT WAS THE GOODYEAR EXCELLANCE SO WENT BACK TO ER 30'S
    I'm clutching at straws here but hope it's of use. - THANKS FOR THE TIP ON THE CLUTCH / GEAR BOX
  1. Mechanical Sympathy
    By VXR_DV in forum Comedy & Humour
    Last Post: 14th December 2011, 21:50
  2. Replacing tie rod any help/tips appreciated
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2010, 14:18
  3. Strange Sound from Car - any tips much appreciated
    By textilewales in forum Vectra C / Signum Troubleshooting
    Last Post: 20th May 2009, 15:29
  4. any tips on how to cut the rear valance to show my exhaust tips
    Last Post: 2nd July 2008, 18:58
  5. Mechanical Sympathy....
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th November 2007, 15:25
