Thread: GSi oil change - What size hex is the filter can and how careful do you need to be?
    Regular Member muffking's Avatar
    Default GSi oil change - What size hex is the filter can and how careful do you need to be?
    As title.
    Gonna do an oil service on the GSi 2mo, but came a cropper last weekend when I didn't have anything that fits the metal oil filter holder. Do I need any special tools as I've heared that you can't use sockets for fear of breaking the holder, so I don't know how much to tighten it back on again afterwards.
    Regular Member poves's Avatar
    lancashire
    Just use a socket mate , can't remember which size it is , if your careful you should be ok , just tighten till it nips then chek for leaks.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by poves View Post
    Same here. Used socket on mine. Better access & leverage from under the car.
    EDIT - it's an 'o-ring' seal so doesn't need to be overtight.
    lancashire
    I got to mine from top lol , just take it easy mate , your bigger problem will be the sump plug , dont round it off unless you have an hammer and chisel nearby .
    Mileage : 000
    It is a 23m/m socket for the oil filter.
    Regular Member yorkshireborn's Avatar
    Apr 2006
    Rotherham SouthYorkshire
    Vehicle : Insignia
    Trim : SE
    Engine : 2.0
    Year : 2011
    t45 hex oil plug
    24mm socket oil filter
    Thanks guys.
    Now I know I can use a socket I should be ok, and I'm pretty sure I also have a T45 for the sump
    Regular Member AntB's Avatar
    Trim : GSi
    Mileage : 39k
    Can anyone confirm if the socket required for the filter housing is 23mm or 24mm?
  1. oil filter socket size 1.9 cdti
    By jonny22 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2013, 12:43
  2. 2.2 direct oil filter nut size
    By 06sri in forum Engine & Drivetrain
    Last Post: 19th October 2012, 22:32
  3. Oil Filter Socket Size
    By paulmatty in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2009, 23:23
  4. Can anyone confirm the oil filter cap size please? 2.0dti
    By nickyg in forum Engine & Drivetrain
    Last Post: 19th October 2008, 20:46
