Hi. has anyone ever had the annoying problem of their cold air not working?. even when I put the little snow flake button on which usually works fine the air is roasting! any ideas guys?
turn the heat dial down bud
Either that or you air-con needs regassing/servicing....
i had the same problem even when i turned it to cold ,hot air came out , turned out that it was a litle black box in the passengers side of the center console that was broke (when i changed from hot to cold the box changes it over)
cheers guys. probably cost me a fortune!
