Results 1 to 10 of 17
Thread: Cruise control Trippin out
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    Default Cruise control Trippin out
    I've had the car two weeks and I've got me first problem.
    On the motorway, I can engage cruise control fine no problems but if I want to change speed using the cruise control switches it trips out. Does this when I want to accelerate or decelerate. This happens fairly regularly -mostly in 6th gear, but is intermittent.
    Guessing it'll be a warranty job. Any clues as to what it could be?
    Regular Member blr123's Avatar
    Dundee, scotland
    Hey Brocks.........tell me about it..........I've had my car 22months and from day 2........and yes that's the 2nd day of ownership I've had the same problem and guess what............after a couple of DOZEN vists to Vauxhall it's still playing up ...........and I may well have a speeding ticket on the way because it wouldn't work last Saturday
    So good luck with it hope you get YOURS sorted
    Bryan
    Darlington
    hi
    found a few veccys doing this at my dealership
    we have replaced the clutch switch and none have come back
    worth trying
    Dundee, scotland
    Quote Originally Posted by MadamVectra
    hi
    worth trying
    Well they have replaced the clutch switch a few times on my car along with everything else a few times aswell eh
    Bryan
    Bedfordshire
    I've had a similar problem on my Vectra recently - the cruise control switches itself off at strange intervals. On a long overnight run down to Cornwall recently I noticed that it seemed to happen whenever I changed from full beam to dipped headlights, so I'm guessing there's a dodgy connection in the indicator stalk somewhere. Hasn't been to the dealer to be checked out yet though. Also had one time when the cruise control wouldn't switch on at all, but after an engine re-start all was fine again. I have wondered since whether this was because I hadn't use the brakes (came straight out of a service station onto the M5 in the early hours). I read somewhere in the manual afterwards that the cruise control won't turn on until the brakelights have self checked...
    Melbourne, Australia
    Quote Originally Posted by MarkySparky
    On cars with manual transmissions, you can't engage the cruise control until the brake switch has been activated at least once. I believe this is to verify that the brake switch actually works.
    Regular Member cyb's Avatar
    Did you all know about the recall on the vectra-C to change the spring on the brake pedal?
    the cruise control will fail to work if the brake pedal does not return to the correct position and some early models had a weak spring which will be replaced FOC.
    Just wondering if this is related to the problems you are having?
    Feb 2006
    Wirral
    Well it was booked in for tomorrow but....They haven't got the Expertese so they've cancelled. Will have to arrange another day.
    It only trips out when I try to adjust the speed with the stalk. Wortst case, Once it starts trippin out it won't re-engage. However on some journeys (like this morning it was fine). I'm thinking the stalk myself.
    Dec 2005
    In the sponge-monkey tent
    Had this problem with mine for a while, cured itself though after a while.
    Quote Originally Posted by cyb
    Just to confirm, cyb:
    I was aware that there were issues with the clutch pedal, but are there also known problems with the brake pedal switch?
    Ta.
  1. Cruise control and MPG
    By golfpro in forum Vectra C / Signum Car Chat
    Last Post: 19th June 2012, 13:44
  2. cruise control
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2008, 20:48
  3. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  4. Cruise Control
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 22:37
  5. Cruise Control
    By 2.0 DTI SXI in forum Vectra C / Signum Car Chat
    Last Post: 22nd May 2007, 17:36
