Thread: tyre Pressures
    Regular Member johnboycdti's Avatar
    rotherham
    Default tyre Pressures
    HI i have a vectrs 1.9cdti150bhp 5 door hatch running standard tyres what tyre pressures should i be using as the manual i got with the car does not state the correct tyre pressures for my car...
    Regular Member Doug-SRidirect's Avatar
    Hemel Hempstead
    The recommended pressures should be stated on a sticker on the driver's 'B' pillar - at least they are on mine. I've experimented a little and found that 35 to 36psi gives a nice balance of ride quality to handling sharpness. The sticker says 32psi.
    Doug
    The Blackburn End
    Doug, what tyres are you running those pressure's on. I've got hard compound Bridgestone Turanza's running 32psi, dependant on your tyres I might pump them up a little and trial it.
    Hemel Hempstead
    Goodyear's
    Regular Member Meriva OPC's Avatar
    Jan 2006
    Just Chilling
    As a rule of thumb I was always taught tyre pressure = wheel size x 2. Therefore 17 inch wheels have a tyre pressure of 34 Psi 16 inch = 32Psi etc. This was only to be used as an interim measure until you found out the exact measurement
  1. Tyre pressures
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2012, 01:00
  2. Eco tyre pressures
    By Mike57 in forum Handling & Braking
    Last Post: 29th February 2012, 14:31
  3. Tyre Pressures
    By Tango in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2009, 00:10
  4. Track Use Tyre Pressures and Tyre Temperatures
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 12th August 2009, 23:04
  5. Tyre Pressures
    By johnmac in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2006, 00:49
tyre pressure for 17 inch wheels on vauxhal signum
