Thread: ABS Light?
    Regular Member GoldenWonder's Avatar
    Durham
    Default ABS Light?
    Is the abs light supposed to come on when the abs is actually working? I.e when you brake hard enough for it to come on.
    My abs light comes on with the ignition, but I noticed the other night when I braked over a sheet of ice and the abs kicked in, that the light didn't come on.
    Used to in some of my old cars but not sure if it does on the Vec?
    (and I can't find the manual before anyone suggests that! )
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    could of been the traction control kicking in
    Chester
    Just looked it up in the handbook and it says it should come on with the ignition while it does its checks etc. The only time it will light up while driving is if their is a fault with the system. so yours sounds like it's working properly.
    Hope that helps
    Durham
    Ahh cheers mate - thats put my mind at rest.
    Will try and search for the manual over the weekend if its not too cold
    6 Post(s)
    Quote Originally Posted by d16wal View Post
    Hope that helps
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, indeed.
    Full Member Penfold101's Avatar
    Wise words from Ste there.... So that's how you get your post count up....
    Durham
    Its the first time since I've had the car (1 year) that I've felt the ABS come on, so was expecting the light to flicker like it did in my previous cars.
    Now, where the hell is that manual!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Penfold101 View Post
    No spam here, mate. Just reinforcing the previous message.
    By Shadrack in forum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
