Thread: Think gearbox has gone
    Regular Member vectra-c1000's Avatar
    in a veccy
    Default Think gearbox has gone
    As above was drivin home and the car come to a stand still no warning or anything so started it up no problem but it will only drive in 1st gear... even in neutral its in 1st...Gear stick moves into gear but thats it think it has siezed in 1st anyone had this problem am i looking at a new gearbox OH NO vectra c 52 plate 2.2 dti sri 16 valve what gearbox is in mine been told it could be the f35 who does cheap boxes or repairs ?
    Thanks vectra c .com.
    Regular Member s0501291's Avatar
    Warrington
    Erm, just somthing to check, From what youve said about "in neutral its in 1st". It could be the control cables from the gear stick to the gear box. If you look under the bonnet you should see 2 big cables connected to a mechanism on top of the gear box. The cables look like brake cables that you get on a push bike. When you move the gear stick it pulls or pushes the cables and moves the mechanism which selects the gear. If its just this cable/mechanism thats broken then its not as expensive as a new gear box
    Hope thats of some use
    Pete
    in a veccy
    No they are ok i did try that first mant thanks though.
    Chester
    Sounds like a broken selector fork
    If it is you'll be able to see it from the engine bay. Look at where the gear shift rods enter the gearbox and you'll see them and what state they are in.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Can you actually engage any other gear with the gearstick? If you can, does it effectively lock the gearbox?
    I has this on a previous car of mine (Mk 2 Astra) - the selector fork actuator had jumped out of it's location on the fork, meaning that it wouldn't disengage the gear (5th gear on mine).
    Maybe yours has done the same? It was easy to fix, remove the selector input cover on the gearbox and reset the selector forks into neutral position and the same with the gearstick and refit. Done.
    in a veccy
    Hi thanks everyone but am no good at cars not one bit haha but if there is anyone local that would have the time to look at it for me would be a great help am in newcastle upon tyne.
    in a veccy
    Well its goin in 2morra now fingers crossed.
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
