Results 1 to 10 of 19
Thread: Air Box v K&N v Upgrade Confused!!!!
    Bedfordshire
    Smile Air Box v K&N v Upgrade Confused!!!!
    I am planning on upgrading my Airbox or putting a new panel filter and would welcome some 1/2 sensible advise.
    Currently have a 1.9ctdi 150bhp Sri and would like a bit more poke.
    I have read info on the "home" Box conversion, but slightly nervous on butching the car!!.
    Other thoughts are straight K&N Panel filter, although i have been told that wont make much difference.
    Lastly, Induction Kit, but confused on which one, do not want one that is too noisy, but wont mind a bit more grunt.
    Over to you lot! You have been very helpfull with all your other advise.
    Heres in anticipation!!
    Regular Member VXR CDTi's Avatar
    Jan 2008
    South Wales
    K&N panel filter and Air Box Mod will give u about 8-11bhp extra like mine. Iv had the car on a rolling road and the results were 158bhp with those 2 peformance mods!
    Pointless messing around fitting an induction kit unless uv got a cold air flow directly into the intake, if anything ull probably loose power if fitted badly!!!
    Here is the HOW2 on changing 2 a performance air filter and doing the air box mod:
    http://www.vectra-c.com/forum/showthread.php?t=54506
    EVERYWHERE
    The air box mod is free,whereas the K&N isn't.I've got a little used K&N still in its box.Nuff said.
    Regular Member mikey68's Avatar
    May 2008
    aberdeen
    Diesel Dog, What exactly is the DMF rattle, if you don't mind me asking?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by mikey68 View Post
    Pray you never find out
    Regular Member shan's Avatar
    Dual Mass Flywheel.
    "Clutch"
    Your spot on with that if the car's out of warranty.
    EVERYWHERE
    Instead of putting a conventional one-piece fly-wheel onto the back of the engine,Vauxhall (and others) have decided to inflict upon us a 'dual mass fly-wheel' whereby a balance weight is situated inside the fly-wheel and this moves around,counter-acted by springs,which supposedly helps stop vibration.
    In reality the springs eventually break and so the balance weight as more freedom of movement and can also break.Everything is contained within the fly-wheel so there isn't any danger of anything coming adrift.
    It's just annoying more than anything and expensive to fix because of the necessity to not only fit a new fly-wheel,but also a new clutch and possibly clutch slave cylinder seals.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by shan View Post
    Hmm, like mine - but its reet, I've kind of become acustomed to it now, I'd miss it if it wasn't there
    Bedfordshire
    Scary Chaps,
    After reading the info on the Airbox , which is working well. I continued to read about the Flywheel.
    To add insult to injury , VX are changing mine after Xmas under Warranty!! Sods law, its just started humming!!
    All the best
    Midlands
    Quote Originally Posted by VXR CDTi View Post
    A panel filter and removing a trumpet won't give anything like 8-11bhp. Your car was probably above the book figure in the first place. I can recommend pipercross filters.
  1. upgrade the 314mm to vxr set up or upgrade the rears?????
    By rob warrington in forum Handling & Braking
    Last Post: 24th September 2012, 09:26
  2. am confused
    Last Post: 6th August 2011, 12:34
  3. Confused
    Last Post: 25th May 2011, 13:35
  4. Confused Dog
    By carlton in forum Comedy & Humour
    Last Post: 16th July 2008, 23:39
  5. I'm confused!
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2008, 14:08
