Results 1 to 3 of 3
Thread: Headlight alignment
    Regular Member The Gas Man's Avatar
    Feb 2006
    north east
    Default Headlight alignment
    Hi i have just fitted SRI headlights to my elegance , the problem is that the main beam from the lights does not seem to reach as far, the motors on the lights work fine ! is there any way i can increse the range without going to vx dealer ?
    Apr 2006
    Ash, Nr Aldershot
    On my 1.8LS if you look down at the headlamps from above you can see white plastic allen key adjusters two on each lamp. The outer ones adjust the left/right and the inner ones adjust the range. Find an allen key to fit turn the adjusters clockwise to lower the lamps and anti-clockwise to raise them. Hope this is of use
    Feb 2006
    north east
    thanks tony your help is appreciated
  1. Headlight Alignment
    By 12345 in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2012, 20:11
  2. Headlight Alignment
    By maurauth in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2009, 17:16
  3. WARNING - Headlight Alignment!
    By parapaul in forum Vectra C / Signum Car Chat
    Last Post: 19th July 2008, 18:28
  4. headlight alignment
    By shy_stag in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2007, 17:14
  5. Headlight Alignment help needed?
    By sparky71a in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2006, 15:58
