Results 1 to 3 of 3
Thread: Help Diagnosing (Possibly DMF)
    N.Wales
    Default Help Diagnosing (Possibly DMF)
    Guys,
    Recently my v6 CDTI has developed a somewhat annoying kind of rattle when i press the clutch.
    When i say rattle, it's more like that classic diesel noise, but just a little bit louder, nothing major but i notice it.
    It only happens when i de-press the clutch about half way, but then goes if i press it right down to the floor, and also goes when i bring it up to bite point and accelerate away.
    One thing that i also noticed was that a couple of times recently it's been a little 'notchy' getting it into first but that could be down to the rapid decline in temperature we've had recently?
    I'm in two minds whether it's possibly the bearing in the clutch of similar or (i'm hoping not) the start of DMF failure.
    The cars a 55 plate and done 41k... any ideas?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    From the description, it certainly sounds like the classic DMF symptoms.
    EVERYWHERE
    My V6 diesel also has the same problem.Symptoms are annoying rattle/clatter in neutral at idle,goes away when you press the clutch pedal down,strange noise when you blip the throttle and then settles down to idle.Also a noise when slowing down in the lower gears (foot off gas pedal).Sometimes it will also completely disappear for days and then come back with a vengance!
    Current diagnosis is failed/failing DMF.Further investigation is necessary.
  1. Diagnosing suspension knock
    By djlee in forum Suspension, Wheels & Brakes
    Last Post: 28th July 2012, 11:41
  2. diagnosing faulty bosch vp44 pump
    By lenny32 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th August 2011, 22:56
  3. MLC possibly ?
    By FIL 4822 in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 16th November 2008, 19:07
  4. Tooling myself up to start diagnosing my Vectra's faults!
    By gekornro in forum Vectra C / Signum Car Chat
    Last Post: 16th February 2008, 12:49
  5. Possibly a new car for me ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2007, 20:30
