Results 1 to 3 of 3
Thread: Lambda sensor and emissions light
    linlithgow
    Default Lambda sensor and emissions light
    My emissions light has been on for the last month or so with the car showing no ill effect whatsoever. In my wisdom, I assumed that it was the lambda sensor and changed this out yesterday but guess what... the light is still on.
    Thinking about it last night, might it be the case that I need to disconnect the battery for 1 hour to let the ECU learn the new values for the sensor or have I just wasted my money by not getting it diagnosed properly?
    Mike
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    I would try disconecting battery first mate just to make sure it should clear any fault codes
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    I think you may need to look at the cam sensor as well as they are somehow connected & throw each others codes off, can some-one confirm ?
  1. where to buy Lambda Sensor
    By signum04 in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2012, 08:56
  2. Lambda Sensor
    By Sambor in forum Engine & Drivetrain
    Last Post: 14th June 2010, 19:43
  3. Lambda sensor
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 13:08
  4. lambda sensor again!
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:49
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
emissions light on vectra c
