Thread: centre screen layout
    Regular Member mat100edt's Avatar
    south coast
    Default centre screen layout
    i think i read some where (cant remember where) that you can get the date to stay up in the top centre of the centre dash screen.
    I am fitting new stereo so when i remove standard one the radio and CD track info will obviously not come up...... so the question is can i get the date to come up to relacethis once new stereo fitted???? if so how???
    Mat
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    would like to know to
    south coast
    im almost sure i read this some where, cant for the life of me think where??
    Engine : 2.2 Direct
    just found on a norwegian forum (www.omc.no) that on Astra F its the grey wire with red stripe that neede to be removed/cut
    not sure about the vec.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    You can actually get a lead so if you fit some HU's like sony then the info will show up on the screen like the stock one. MP3 and track info ect.
    Kent
    do you know which head units work like this or what the lead is called?
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    south coast
    cheers alzsxi, good thread. the only thing is i have a different display to that, iv not seen that display in a C before it looks very much the same as the VEC B display. i will fint out if this works any way as i will need to cut the blue remote cblehe is on about to turn on amp when installed.
    Mat
    Blantyre
    Ok, simple enough, which wire is connected from the headunit into the loom and goes live when the unit is switched on? Of course, the old electric aerial lead, a quick test with a multi-meter confirmed this was the culprit so I removed the cable from the adaptor completely and everything works just fine and I keep my time, temperature and date on the dash display. So, tonights hard work results in this...
    taken from the thread
  1. Centre Screen
    By Carl83 in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2012, 17:09
  2. Problem with centre screen
    By ScotsDragon in forum Electrical & ICE (including SatNav)
    Last Post: 7th March 2011, 20:27
  3. centre trip screen
    By Deacon in forum Vectra C / Signum Car Chat
    Last Post: 21st August 2009, 13:28
  4. Centre screen out :0(
    By big O in forum Electrical & ICE (including SatNav)
    Last Post: 18th December 2007, 18:18
  5. Centre screen protection
    By Darrell in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2007, 05:31
