Results 1 to 10 of 11
Thread: need some help with this
    rubgy
    Default need some help with this
    took my car to AUTOLEC SERVICE and they stuck it on a code reader and this is what came back
    (as printed on the sheet)
    1)-no communication with steeringwheel angle sensor (cim)
    2)-data from body control module -BCM-(incorrect signal)
    3)-U2113- not registered code
    4)-CAN message from engine control unit no communication
    5)-loss of serial data communication of ABS/TCS
    6)-u2111-not registeredcode
    dose anybody no what all this means and maybe what the fault could be as all they could tell me was it has a can fault and the car would have to be rip a part to find the fault and that id be looking several hundreds of pound to do so which i dont have just before christmas
    thanks for looking
    OK, ignoring the fault codes for the moment - what is actually wrong with the car in terms of symptoms etc.?
    Fault codes can be thrown up sporadically when a reading is out of range for some reason and never cause an issue/come back again - so a bunch of logged fault codes doesn't tell too much without knowing what your problems are.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    What were your problems/symptons before you took it in? A bit more info might help us help you.
    Obviously something prompted you to do it .
    EDIT - beaten to it by Duncan (again and again and again).
    rubgy
    symptoms are when the car is started the main head lights will turn them self on at that point of coming on the main dash will die and ther will be no indercators & spedo and rev counter will not move. turn it of and start it again and its fine untill the lights come bak on
    OK, that 'may' be a CIM module as what you've described is symptomatic of a dodgy CIM.
    But before you go out shelling out for a new one, as they are about £300, you need a proper diagnosis/confirmation that it is faulty. A bloke at an Autolec printing out a bunch of fault codes is not a diagnosis - any monkey with a code reader can do that.
    rubgy
    Thanks for that mate i will see if i can get it tested
    Regular Member garvey's Avatar
    Co Durham
    May be worth checking ABS plug
    Yep, I thought about that when I posted beore - I just wasn't sure if you'd get all those symptoms with that? For the sake of giving it a clean etc., certainly worth trying first.
    rubgy
    just had a thought just before all this started happening to my car i had to stop my car from being hit by another drive and i hit the curb hard on the drivers side do u think it could it be possible a wire has come away in the cim .
    rubgy
    can any one tell me where the abs plug is located
