Hello People. I have 53 plate 2.0dti ls Vectra. The cruise control has stopped working. Any suggestions ?????????????. Thanks
Hi and wellcome to the site,when your driving ease your foot under the clutch and see if it lifts slightly,also do the same with the brake...this is because the spring might be cream crackered on either pedal or both..if you have the loose spring its not that much to replace so dont panic.
hi
if the spring has gone its only about £7 for the spring kit from vx
mine went earler in the year
easy to do yourself m8
Clutch spring mod:-
http://www.vectra-c.com/forum/showthread.php?t=33621
Could also be a dodgy stalk but more likely the spring on the pedals![]()
Probably easier just to buy a replacement stalk than strip the other one down and obtain the spare parts required.
check that your brake lights work as when mine had the stereo replaced they pulled the wrong fuse and put it back in a different place,its the same fuse for cruise control as brakes.My green disp light didnt come on till i put the fuse back in the right place had drove around for three days with no brake lights
