Thread: CDTi 150 Misfire - clear things up for me!!
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default CDTi 150 Misfire - clear things up for me!!
    OK, done the search but cannot find a definitive answer.
    Got the 2k revs misfire which is probably THE most annoying thing in the world.
    Struggles to take off from junctions etc, cruising along and press the throttle and nothing happens.
    No warning light or fault code though. Is it more likely to be the injector (#3) or the EGR valve coke-up?
    No DPF on the car and has done 46k odd miles and is a pre-facelift SRi.
    Garage think its most likely the injector but surely this would throw up a code?
    Started the car a few times now and it runs smooth and idles perfect but press the throttle and nothing at all.
    Sorry for ANOTHER thread on this but just need closure and a definitive answer.
    TIA.
    Jan 2006
    Dalriada
    TBH sounds like the EGR valve mate
    Tain - Easter Ross
    Went to Vaux today to ask them. The brick wall was probably more helpful!
    I would do the EGR myself if I had time but time is a luxury I do not have much of these days.
    Oct 2007
    Gloucester
    Recently had the same symptoms. First garage changed the mass air flow meter and then a vacuum hose. Neither helped.
    Then got the EGR valve changed and everything is back to normal.
    Sounds like that's your problem too.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Injector no.3 issue I think. Had the same problem the other week. Have the engine running with its misfire and push injector no.3 plug and see if the misfire stops. It might not as the cable could have broke down totally. As you stand in front of the engine the injectors are no1 left through to no4 on the right.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Tain - Easter Ross
    Idles perfectly. Had the 'car and spanner' pop up a couple of times today, had the code read (not by vaux) and there was no code stored!
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    The fact that by pressing the throttle does nothing seems to point to the EGR, as an injector fault would make the car run normally, but with some misfire and hesitancy. I cleaned the plugs of my injectors and tie wrapped number three on (as they are quite loose) and its been spot on since - only takes 5 mins too, as like you, I have no time to do things like this any more
    Tain - Easter Ross
    £40 plus VAT at Vaux for them to tell me the EGR was faulty. Got one through work for £96 all in including the 2 gaskets and now its fitted, problem solved.
    Oct 2007
    Gloucester
    I'm amazed at how many problems there seem to be with the EGR valve. Why don't Vauxhall make cleaning it a part of the service routine. It surely can't take that much time to do it and it would certainly be a hugely beneficial for all us 1.9 drivers.
  1. Misfire 1.9 cdti 120
    By matt2002 in forum Engine & Drivetrain
    Last Post: 18th April 2011, 08:38
  2. misfire on a 150 cdti- help pls
    By robk6112 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2011, 11:21
  3. 1.9 CDTi MISFIRE
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 19th March 2009, 23:28
  4. Misfire on CDTI SRI 1.9
    By Warrenmole in forum Engine & Drivetrain
    Last Post: 3rd August 2008, 21:06
  5. 1.9 cdti misfire
    By johnboycdti in forum Engine & Drivetrain
    Last Post: 10th March 2007, 10:37
