Thread: MAFlow Voltage output.. Help
    Wakefield
    Default MAFlow Voltage output.. Help
    Anyone got any idea if the Mass Air Flow should be giving a voltage output?
    Had the vectra cdti 150 hooked up to a diagnostics machine, it did not display any fault codes, but the guy said the Mass Air Flow sensor is not displaying any voltage
    should it be? do i need a new MAF sensor?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    The diagnostic machine should be able to show live data, it will output a voltage between high and low. Normally between 0 and 5V
    Wakefield
    It was displaying 0 at idle, when revs were given it stayed at 0.
    is that correct?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Prob not. Dirty ?
  1. Instrument Dimming Bulb Output Circuit Open or High Voltage
    By SlowCoach in forum Vectra C / Signum Car Chat
    Last Post: 1st September 2016, 20:24
  2. boost pressure sensor input and output voltage???
    By FLOB in forum Engine & Drivetrain
    Last Post: 24th April 2012, 14:58
  3. Op-Com ERROR: B3109 - Remote-Key 1 System Voltage Low Voltage
    By Jedi in forum Vectra C / Signum Troubleshooting
    Last Post: 30th June 2010, 18:17
  4. 2.2 SRi single output to twin output (direct) conversion
    By waqas in forum Petrol Engine related
    Last Post: 18th January 2010, 02:10
  5. Iso to aux output adaptor.
    By fastcarmanaic in forum Electrical & ICE (including SatNav)
    Last Post: 13th December 2009, 23:21
