Results 1 to 2 of 2
Thread: ABS light
    Mudeford
    Default ABS light
    My 52 reg 2.0 diesel vectra has ABS light coming on intermedently. But when it's on it stays on for the remainder of the drive. Had it diagnosed that the front nearside sensor needed changing. Bought a new sensor which comes together with the whole hub and had it replaced over the weekend. The light still comes on. Diagnostics gives same reading. Local garage says that the new sensor might have been faulty? Any views please.
    Glasgow
    Mine does it too, doesn't come on during my normal commute but last week i drove to Birmingham and back over the weekend and the ABS light was on for some of the way. My mate said that the wheel sensor is magnetic and can pick up little bits of metal swarf causing the light to come on, this can be fixed by careful cleaning. I've not cleaned mine yet due to the weather but i'll give it a try and hopefully it'll cure it.
    Jim.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
