Thread: about chip tuning???
    Oct 2007
    Ankara
    Default about chip tuning???
    hi all
    i ve vectra 2.0 turbo as u know
    i wanna learn about chip tuning.. there is a many company in Turkey about chip tuning. they give many different hp and torq
    upsolute chip tuning
    my car 175 hp to 205 they do..
    wimmer
    221 hp
    superchips
    211 hp
    bsr
    215 hp
    vmax
    210 hp
    which chips tuning company is better.
    if u were me . which one would u prefer??
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Alot of people on here mate go for BSR
    Id say BSR all the way mate
    Regular Member big O's Avatar
    Good old Sunny Scunny!!!!
    BSR mate, i can't fault it.
    Regular Member mushy2007's Avatar
    Liverpool
    BSR would be your best solution, I am sure Duncan and Mark will be along to give their thoughts as they run the same.
    Somebody call?
    As others have said, I also wouldn't hesitate in recommending BSR. Out of the list you gave I've only heard of Superchips, but don't know exactly how their remap performs on a 2.0T.
    BSR are tried, tested and trusted - you only have to look at the reports on here from people that have their product to see how pleased they are.
    Given your engine and list of possibilities - BSR every time from me.
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    Worcs/Staffs/Westmids (ish)
    Make sure it doesn't eliminate the knock sensor input to the ECU, a lot of the cheep one's do this as it's a nice easy way to gain more power, until the pistons disintegrate at least.
    Without too much detail it forces the ignition timing to assume your running high octane fuel, giving you a boost in power when using super. So when you stick regular old unleaded in there you'll start chewing your pistons up.
    In extreme cases you could blow an engine in just 2000miles.
    It's well worth investigating before spending money.
  1. 1.9 cdti 150 tuning chip
    By Mickyshort in forum Diesel Engine related
    Last Post: 24th April 2012, 18:56
  2. Dtuk tuning chip
    By Vectracdti150 in forum Diesel Engine related
    Last Post: 25th July 2010, 07:13
  3. Chip tuning for 1.9 SRI CDTI 150. Where can I get?
    By Sums in forum Diesel Engine related
    Last Post: 4th September 2009, 17:04
  4. Tuning chip
    By Guyver1 in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2008, 16:57
  5. Diesel tuning chip
    Last Post: 1st August 2008, 20:51
