Results 1 to 10 of 13
Thread: Humming Noise!!!!!
    May 2008
    Wrexham
    Default Humming Noise!!!!!
    Another question Guys
    I have a humming noise coming from the front drivers side, it gets louder and more droning the faster i go, and the noise slows down as the car slows down. Also i can feel slight vibration on the pedals.
    Im thinking its possibly a noisy tyre, but can it be anything else?
    birmingham
    Vehicle : Vectra gsi
    Trim : Full heated leather
    Engine : 3200
    could be a wheel bearing but put the spare on and see if its a noisey tyre
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    that would be a wheel bearing fella, and they cost £145 plus vat at the dealers but does come with the ABS sensor
    May 2008
    Wrexham
    Quote Originally Posted by glynn View Post
    its only just gone through the Mot
    wouldnt the wheel bearing of been picked up on that?
    is the dealer the only place for a bearing or is it cheaper elsewhere?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    try ebay or autovaux 01924 376003
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by liphook View Post
    Mine developed the same sound a week after its MOT.
    With the modern type bearings you can't detect movement simply by rocking the wheel when it's off the ground. Something to do with the modern design of the bearing assembly think.
    Had mine done at a local garage (not VX) and bill came to £200 and yes, they did fit a genuine VX bearing/hub assembly to the n/s front.
    Plenty of info on this forum and pattern parts on Flea Bay.
    Blantyre
    You can get the bearing and sensor from Ebay, i paid £65 each (2) and fitted them myself, didnt take long and am not mechanically minded these days
    Still didnt solve the noise so it was the tyres
    Slightly miffed
    May 2008
    Wrexham
    Quote Originally Posted by spennny View Post
    Slightly miffed
    Just checked ebay, seems a good price, but which one? there are a few on there for an 03 Vectra, but they all look slightly different.
    Also i am not mecahnicaly minded, is this job easy for a dimwit to do?
    How long can you drive the car with the bearing humming? is it urgent to fix?
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Signum 2.0 DTI (Irmscher)
    Trim : Elegance
    Engine : 2.0 DTI 100 bhp
    You can drop by the Dealers and ask them the part code for the wheel bearing for your car, search on Ebay for the one you need.
    You really should rule out the trye first as it is a very easy job and no cost to switch wheels. Then if it is not the trye then it is defo a noisy wheel bearing. Although it may be noisy it doesn't neceserally mean it's faulty unless it's excessively noisy.
    to the site anyway.
    Bri.
    Regular Member boba's Avatar
    The Kingdom of Fife!
    If it's badly worn you can hear and feel the bearing grate slightly if you spin the wheel gently and listen close in to the hub. Generally a wheel bearing will start to make enough noise that you fix it long before it gets round to failing so very unlikely to fail in an MOT IMHO. You'd usually get many hundreds of miles from a bearing after the noise got so loud you started to panic.
  1. Humming noise
    By skip85 in forum Suspension, Wheels & Brakes
    Last Post: 16th May 2011, 09:35
  2. Humming !
    By G4GAV in forum Diesel Engine related
    Last Post: 16th June 2010, 13:02
  3. very bumpy humming noise when speed up
    By peter p in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 08:15
  4. Front end humming vibrating noise!!!
    By Days of thunder in forum Vectra C / Signum Car Chat
    Last Post: 25th April 2009, 07:03
  5. humming noise over 30mph, HELP!!!
    By whatthevecisup in forum Suspension, Wheels & Brakes
    Last Post: 10th April 2008, 15:01
vauxhall insignia humming noise
vauxhall insignia making humming noise
vectra c road noise
humming noise vauxhall insignia
