Results 1 to 10 of 14
Thread: usb stick
    Regular Member garvey's Avatar
    Co Durham
    Default usb stick
    I have a memory stick, when i put it in my usb slot it make the noise then it appears in my computer but when I click on it it says please insert a disk into the drive. is there anything I can do or should i just put it in the bin
    Blantyre
    Did you give it time to install itself ...and not click it straight away
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    As said above make sure drivers installed and if you see it in my computer are you Sure its the memory stick your looking at as card readers etc come up as a drive letter with removable disk next to em! try a different usb slot... oh and if you do want a new one play.com has 16gb on for £15 just snapped one up myself.. as my 4gb tends to get full HTH
    Co Durham
    it autoplays searching, but nothing else
    Nov 2007
    You could right click on it in my computer and format it... quick format will do BUT THIS WILL WIPE IT.
    Blantyre
    is there stuff on it ??
    If not then right click and format it, takes a few seconds, and you can rename it if you like, then remove it, and try putting it back in
    wait 5-10 seconds and see if you can see it now
    Blantyre
    Quote Originally Posted by steve View Post
    lol.... to quick mate
    Nov 2007
    Quote Originally Posted by spennny View Post
    lol.... To quick mate
    Co Durham
    there is loads of pics and documents on it. luckily I have another one with the same data on. it will not format when you check its properties the pye chart says its empty, off to the bin for it i think.
    Nov 2007
    Quote Originally Posted by garvey View Post
    Yep me thinks it may be broken...
  1. Do you get any stick?
    By Juego in forum Vectra C / Signum Car Chat
    Last Post: 9th May 2011, 17:51
  2. Gear stick
    By Vectra King in forum Vectra C / Signum Troubleshooting
    Last Post: 11th September 2010, 23:54
  3. Will this stick fit?
    By John LE in forum Diesel Engine related
    Last Post: 6th November 2009, 01:36
  4. Best place to stick these?
    By Jake in forum Styling
    Last Post: 30th April 2009, 18:00
