Thread: New Turbo, Inlet Manfiold, and EGR valve and Still Losing Power
    b
    confused New Turbo, Inlet Manfiold, and EGR valve and Still Losing Power
    Hi
    Ok, I got a 54 Signum 1.9cdti a while ago, and I love it... but god Ive had some problems....
    In the last 3 months I have replaced the inlet manifold and turbo due to some fairly serious issues... and it was going fine.
    Towards MOT it felt a bit sluggish and there was a bit of a misfire occasionally... So i was all set just to clean the injector loom wiring...I thew in some injector cleaner...
    The car passed the MOT fine. And subsequently broke down the following day... completely out of the blue. Struggled to start and then misfiring. Absolubtly no power and lumpy not an even close aproximation.
    I cleaned, and then replaced the EGR, and the car seemed to be running fine.Great in fact!
    BUT
    A few days on the car seems to becoming heavy on acceleration again....
    Any ideas? Could I also have injector problems? Fuel filter(although the AA test said the pressure was fine).... Electronics?
    Help!?
    G
    #3 injector issue maybe? - http://www.vectra-c.com/forum/showthread.php?t=62925 - becoming a common problem on the 1.9.
    b
    Thanks, tried cleaning again.
    No real judder any more and just re-cleaned the plugs, just feels 'heavy' when driving... no real Umph, less acceleration, which was there immediately after I changed the EGR valve...
    Yep, but it may be the plug/wiring that needs replaced. Have you inspected the wiring on #3 closely?
    b
    Will do! Very carefully having just read a few posts! Thanks!
    Do you think it could be anything else....? instead of doing this bit by bit.. I'd like to finally resolve all the problems!!!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    It's safer to do it bit by bit then if you have further problems you know where to look
    Oct 2009
    rotherham
    Default Throttle assembley
    Hi Mate, Iv'e got a Vectra 1.9cdti (150) with the same problem. Today I have taken off the throttle assembly and it was made up with crap. There are a couple of veins for the air to circulate from the egr valve that were completely blocked with crud. Cleaned these out and got about half a cup full of crap out the inlet manifold.
    Turbo now running at about 90% and more to the gallon.
    Hope this helps.
    Jul 2009
    lanark
    boost control valve id bet
  1. Losing power*
    By Iezzi-martin in forum Engine & Drivetrain
    Last Post: 27th October 2010, 09:40
  2. Losing power!!
    By bigjjfaetheyy in forum Engine & Drivetrain
    Last Post: 14th May 2010, 08:57
  3. losing power
    By lacom in forum Engine & Drivetrain
    Last Post: 25th November 2008, 09:53
  4. Help Car Keeps Losing Power
    By gregc in forum Engine & Drivetrain
    Last Post: 20th August 2008, 01:07
  5. sri 150 losing power
    By marky2027 in forum Engine & Drivetrain
    Last Post: 25th July 2007, 20:09
