Thread: Spring or Switch 2.0 T clutch
    Apr 2008
    Nottinghamshire
    confused Spring or Switch 2.0 T clutch
    Hi All , Cruise control on my car ( 05 2.0 T ) is not working , I get no indication light on the dash even when I first turn on the ignition and hence will not work whilst driving. Also the engine overrevs when I change gear at highish revs . Have tried lifting both brake and clutch pedals but still no go. Am I right in thinking a defective switch on the clutch pedal could cause both theese faults? and if so does anyone have any experience in changing one??
    Any help appreciated
    Neil B
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    if it gets a dtc for the cluch switch it wont work untill cleared. could be the switch but does the pedal go all the way up? has it the extra spring on the clutch pedal? the switch can be ajusted by pulling the centre out a bit
    Apr 2008
    Nottinghamshire
    The pedal goes all the way up , I tried to lift but had no slack to take up , I have not had a look at the spring yet as it is dark and Pi**ing it down outside! Do you know if the switch could cause the other problem with the gear change , I have a feeling it has some control over engine revs on gear change.
    Eindhoven
    yes think it does, wouldnt of thought its the spring if it goes to the top
    Regular Member lesbo's Avatar
    Feb 2007
    ANGLESEY
    Could also be brake pedal not reseating properly. Cleaned under mine and works fine now
  1. Clutch Spring
    By Ian T in forum Bodywork & Interior
    Last Post: 19th November 2014, 01:19
  2. Clutch Switch & Brake Switch
    By spennny in forum Electrical & ICE (including SatNav)
    Last Post: 29th June 2011, 12:01
  3. Clutch spring kit
    By KEV E in forum Vectra C / Signum Car Chat
    Last Post: 2nd September 2008, 17:02
  4. Clutch Spring
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2008, 15:39
  5. New Clutch Spring
    By Vec-6289 in forum Engine & Drivetrain
    Last Post: 29th September 2007, 19:30
vauxhall vectra c clutch switch what does it do how does it work
switch springs for signum
