Results 1 to 10 of 11
Thread: rear fog lights on vec Estate
    Swindon
    Default rear fog lights on vec Estate
    Here's a question, I'm certain that on the Vec-c Estate, both the rear fog lights work. Does anyone know if they do both work.
    Also how do you remove the rear panel on the boot lid on the Vec-c Estate, so i can get a look at the wiring and also fit my TV tuner into the boot lid.
    Thanks all
    Only one light works on the hatch/saloon and Signum - I'd have thought the estate would be the same? It's normal anyway and the same on lots of other makes.
    Do you mean the interior trim on the tailgate?
    Swindon
    Hey Dunc.
    Yep thats the one, i need to remove the trim on the tail gate. i can't see any visible screws to remove it.
    I don't want to go pulling and breaking things.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Vehicle : Insignia
    Trim : Dynamic
    Engine : 1.6 turbo
    Year : 2019
    Mileage : 44000
    only 1 foglight on the rear of the estate.. (aleast on mine) dont know how to get the trim of
    Regular Member martind511's Avatar
    Swindon
    Vehicle : Audii A3 Sportback
    Trim : S Line Black Edition
    Engine : 2.0 Diesel
    Year : 2011
    Most European cars now have only one foglight which is normally on the drivers side and this is so not to confuse this light with the normal tail/brake lights. The Vectra estate should only have one foglight fitted although iirc the wiring etc should be there for the other light which would be for the left hand drive model.
    Quote Originally Posted by tonyt View Post
    I'm not familiar with the estate, but on the Signum on the interior grab handle there's a screw that needs removed and on the bottom edge there are a couple of expanding rivet fixing things. Then the trim just pulls off as it's attached by the sprung retaining clip things.
    The estate may be the same sort of setup?
    Swindon
    Thanks Dunc. I'll take a look later.
    I need to remove the panel to take a look at the fog's but also to install the TV Tuner for a nice descreet install
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Yep, it's the same on the estate. You'll need to add a wire from the feed to the nearside fog light, from the offside one. (1 wire)
    Regular Member markd3925's Avatar
    Eindhoven
    Vehicle : Vectra GTS
    think there might be 2 screws under the trim that goes around the window aswell. they will be t20 torx screws
    Think you might be right there as I've just remembered it has those on the Signum.
  1. Estate rear lights condensation
    By fastbatard in forum Bodywork & Interior
    Last Post: 25th February 2011, 23:38
  2. Estate Rear Lights
    By a18nmk in forum Electrical & ICE (including SatNav)
    Last Post: 16th April 2010, 10:48
  3. Rear Interior Lights in Estate
    By chaddopete in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2009, 23:10
  4. Rear Interior Lights Fitted in Estate.
    By Vectra-Dog in forum Styling
    Last Post: 4th May 2008, 07:46
  5. rear lights on veccy c estate?????
    By dhallett1 in forum Styling
    Last Post: 12th March 2007, 17:40
vauxhall vectra estate 2.2 direct rear fog lights
