Results 1 to 10 of 11
Thread: Any tips on fitting a os mirror glass?
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Any tips on fitting a os mirror glass?
    mr nobody has cracked mine,as above please guys?
    As it's already broken you won't need to worry about breaking it when removing it - so simply adjust the mirror so that it's pointing inwards towards the car, slip a plastic wedge/spatula or similar in behind the glass and lever it off from the motor mount. New one simply pushes on until it clicks.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    the lads at work say its a nightmare getting the new glass in,they say its more of a "crack" than a "click" as the new one breaks as its been pushed in too hard
    OK, maybe a loud click then.
    It's certainly not a nightmare fitting it - you'd have to be pretty cack-handed to break the glass putting a new one in. All you have to do is make sure you use even force on the middle of the glass when pushing it on as that's where the attaching lugs are that need to click in place. Use the heel of your hand to spread the weight and you'll be fine. If you start pushing on the edges of the mirror then that's when you're likely to start breaking/snapping the glass.
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    do you know me duncan????
    No, but I'm getting a picture!
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    mmmmmmmmm old spice
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hey up bobby... smear a little bit of grease on locating clips line up. thumbs in centre of glass and push if you get stuck i will come and do it for you
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    good lad, good to see all us yorkshire folk stick together
    May 2007
    south ockendon
    i am quite clumsy and even i managed to fit a new o/s mirror glass with no problem
    as said just use even pressure and you will be fine
  1. fitting vxr tips
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 29th September 2012, 18:29
  2. mirror cover & mirror glass
    By Big Knox in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2010, 11:27
  3. HIDS Fitting Tips
    By vcdti in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2009, 17:23
