Thread: Radio problem
    Bristol
    Thumbs up Radio problem
    Hi all,
    Its time for my first post I cant find any info for this problem I've spent ages looking through different post. I bought myself a Sony mex bt-3600 from halfords for £119 and a free £10 coupon its all fitted and working with the autoleads steering wheel controls but every time I turn the radio on the date disappears from the TID I've changed the red and yellow wires round make the radio work bit i've still got the problem with the display.Can anybody cast any light on this one please.
    Thanks in advance
    You don't say what age your motor is.
    If you have a canbus model, then the supply you have may be incorrect.
    I have just put a Kenwood in mine, and learnt the hard way.
    The switched supply on a canbus model is 3v. It is just enough to turn the radio on, the power comes from 12v permanent.
    You need to find another switched live, or wire the two feeds into the permanent live. You just need to remember to switch the unit off every time.
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    You will lose the date as the factory h/u uses the same line to display the radio station etc,just one of those things with fitting an aftermarket h/unit.
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by tyreman View Post
    Depends which year / radio / display he has
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Quote Originally Posted by Ian S100 View Post
    I checked on his profile,a 02, mine's a 03 and i have the problem, so there's a good chance what i said is correct.
    Bristol
    Thank you Gents quick replys it is a 2002 dti I've just ordered a stalk and display Connects2 CTDOPS005 from incar express i'm hoping that will do the trick.
  1. bit of help with a radio problem ????
    By antowens in forum Electrical & ICE (including SatNav)
    Last Post: 28th September 2012, 16:40
  2. Radio Problem
    By Baxworld1 in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2011, 02:42
  3. Radio Problem
    By steve alan in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 16:36
  4. Radio Help Please, Odd Problem
    By Drewm in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2009, 07:55
  5. Radio Problem
    By Trekker5 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2008, 09:52
