Thread: when cold...
    Regular Member Ean's Avatar
    Suffolk
    rolleyes when cold...
    our 2.2 direct has a squeek as the engine is running.
    when warm, nothing. but then again, if i use the car one morning, then go to it another, it may not come in then either....
    Any ideas what this squeek could be? When I rev the car, the squeek does not change.
    Seams to be coming from under the 'plastic cover' in the engine...!
    any thoughts/ideas/help/suggestions would be kool!
    Thanks,
    Ian/
    Sounds like it may be the Multi-V belt tensioner/alternator pulley. Fairly common problem on the 2.0T, which the Z22SE is derived from, or vice versa actually.
    Regular Member sanjeevgangar's Avatar
    bedfordshire
    Quote Originally Posted by Ean View Post
    Thanks,
    Ian/
    Iam finding the same problem in my 2006 1.9 cdti .
    Suffolk
    fairly comon, easy to fix?
    Quick fix, get car running, find the belts, run/rub some 'Crayon' over the belts? ;o) Hehe!
    Seriously though, what should I do?
    Ian.
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. So you think it is cold here.
    By ed taylor in forum General Chat
    Last Post: 23rd December 2009, 15:36
  4. No Cold Air
    By dhwigston in forum Vectra C / Signum Troubleshooting
    Last Post: 18th November 2009, 18:52
  5. A cold one.
    By shan in forum General Chat
    Last Post: 10th September 2007, 00:40
