Thread: Rear Courtesy light wiring
    Stoke-on-Trent
    I wondered if anyone can help, I have tried to find the centre dome wiring ribbon to fit the rear courtesy light into my 2006 Vectra SRi Nav hatch, but cannot find it. I have fitted one previously to my 52 plate SXI without difficulty as the ribbon was coiled under the white sticky patch. I did wonder if the ribbon might be lower down the pillar, but dont want to take the car apart if there's no point. If all else fails, I have considered running a live and earth to the lamp, but without the plug, the conection looks to be difficult. Any help would be appreciated, fastening a baby seat could be so much easier! Thanks
    Chester
    Stoke-on-Trent
    Smile
    Thanks very much - just what I needed! Cheers
    Regular Member Robbie69's Avatar
    I have the same car mate, put simply, there isn't one. Just wire it up yourself from the front light. I did thisd, then got a new loom and fitted that as I wanted illuminated sun visors. HTH
    When I initially wired it up think I used 5amp wire (for auto lighting from Halfrauds). Just soldered then onto the top of the plug where there is already some solder. Easy enough to do and worked a treat. Just don't do what I did and cut the hole in the lining too big!
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Computer audio leads have the same plugs on the end although you may need to join a couple together if you can't find one long enough but it's safer than pulling the light to bits
    Stoke-on-Trent
    Thanks for the advice everyone, I'm going to wire direct from the front light, presumably it won't cause the front one to be dimmer or fade more quickly? Also doesn't cause a bulb failure to come on, like when I wired reversing sensors, before I fitted a relay?
    None of that mate, it will be the same and work perfectly fine, good luck with it.
    Stoke-on-Trent
    Thanks very much, I followed your advice and success, I've tried it and it works! I just need to lower the headlining again to thread the wire from the front light to the back - weather permitting tomorrow. Cheers
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    Quote Originally Posted by Street N View Post
    Just done mine today and its great... my passangers can finaly see
    Glad it worked for you, good luck mate.
  1. Rear int light wiring
    By Chewy72 in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2012, 22:37
  2. Rear light cluster wiring
    By Grumpy1954 in forum Vectra C / Signum Car Chat
    Last Post: 30th September 2010, 19:51
  3. Rear Internal Courtesy Light
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 24th November 2006, 09:21
https:www.vectra-c.comforumshowthread.php63908-Rear-Courtesy-light-wiring
