Thread: reversing sensors
    Chester
    Default reversing sensors
    Hi all
    I've just started emptying the boot ready to start taking off the rear bumper to fit parking sensors. Am I best to disconect the battery for this job and if so which lead should i take off, Pos or neg. Also will this affect the radio when i reconnect?
    Thanks in advance.
    Mileage : 000
    If you are disconecting the battery you WILL lose the radio code ( but I think if it is a later face lift you don,t?). It is best to disconect the Negative terminal. ( -)
    Chester
    Thanks, It's a 2007 so hopefully radio will be ok.
    Mileage : 000
    The alarm might go off when you reconect the battery, have your keys at hand just in case.
    11 Post(s)
    It might also go off when you disconnect the battery as the power sounder has a backup battery (or at least it used to). The procedure was to turn on the ignition and turn off, then disconnect the battery within 15 seconds to prevent the alarm from sounding. Might not apply to newer Vauxhalls though.
  1. reversing sensors
    By redo in forum Electrical & ICE (including SatNav)
    Last Post: 8th May 2012, 19:27
  2. reversing sensors
    By markj23 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd October 2011, 21:10
  3. reversing sensors HELP PLEASE
    By SRIRob in forum Styling
    Last Post: 20th January 2010, 14:43
  4. Reversing sensors
    By d16wal in forum Electrical & ICE (including SatNav)
    Last Post: 27th November 2008, 00:48
  5. which reversing sensors please?
    By wardy in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2007, 21:48
