Thread: What do u lose on display when fitting aftermarket head unit?
    Regular Member Rikkiola's Avatar
    Feb 2006
    Dunstable
    Question What do u lose on display when fitting aftermarket head unit?
    As I see it there are 4 main things on my display:
    1) Date and time
    2) Temperature
    3) Radio name/CD name
    4) trip comp info (e.g inst consumption)
    also... warning messages (e.g. washer fluid level)
    If you fit an aftermarket unit, which of these do you lose?
    Do any of the steering wheel controls work any aftermarket units? Only certain models if yes?
    SOUTH SHIELDS
    You just lose the radio station name/cd name
    as rob said mate, but you can buy an adapter for this at about £40, will try and find one once you let me know what headunit you have..
    Feb 2006
    USA
    Also when you turn on the radio, the top line of the display which normally shows the date will go blank. I believe this is down to the display detecting the radio switched on, probably using the automatic antenna connection. It should be possible to retain the date on the top of the screen by disconnecting this cable.
  1. Aftermarket head unit
    By Alansvecky in forum Electrical & ICE (including SatNav)
    Last Post: 2nd December 2011, 20:23
  2. Help fitting double din head unit... aftermarket cage question?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 10:23
  3. Do I lose BC if I change head unit?
    By Steveocee in forum Electrical & ICE (including SatNav)
    Last Post: 24th August 2011, 16:17
  4. Aftermarket Head Unit + Info Display HELP
    By SRI Alex in forum Electrical & ICE (including SatNav)
    Last Post: 22nd May 2011, 12:56
  5. Help with fitting an aftermarket head unit.
    By alembicbassman in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2010, 19:29
