Thread: Nasty Trim Rattle
    Merseyside
    Default Nasty Trim Rattle
    Somewhere around the steering column, there is a nasty resonating rattle when IU pull away from a standing start. I think I've traced it to the panel at the right hand side of the centre console. I have noticed that this entire panel moves when I put gentle pressure on it - is this movement normal or is it off to the stealers and some warranty work?
    Will photgraph it if needed.
    Surrey
    Can you take a pic of where you exactly mean.
    Merseyside
    will do...... right now
    Merseyside
    Pics are as follows:
    When I lean my left knee gentle against the side panel of the console, the rattle stops completely
    Merseyside
    Top pic should read - this is the problem panel..... I think.
    2nd pic should read that entire console outer trim moves in arrowed direction under gentle pressure....
    Administrator plasma's Avatar
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    in the bottom pic theres the round blanking plug. Pop that off carefully, you'll see a torx screw head under that with a nut around it too.. The torx screw can work loose and thus in turn the nut vibrates and rattles... U can hold the torx screw still and tighten the nut up.. Worth a check
    Merseyside
    Merseyside
    Rhanks for the reply - will take a look at it on my way to work. Although it does sound quite a loud rattle.
    On the Forum
    538 Post(s)
    Engine : 150
    Mileage : 74000
    other option is to remove the whole centre console which is fairly easy and then you can diagnose it with it removed.
    Merseyside
    I'll have a look at it now before I go to work.
    Its still in warranty, so is it worth me getting the stealer to do it - they might wash the dirt off the paint for me too!
  1. nasty !
    By john norris in forum Comedy & Humour
    Last Post: 23rd November 2012, 21:59
  2. Could Have been nasty!
    By BigMan in forum Vectra C / Signum Car Chat
    Last Post: 5th July 2007, 15:52
  3. OMG - Could have been really nasty
    By john_k_sri in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2007, 12:09
  4. Door trim rattle
    By stevedee3 in forum Bodywork & Interior
    Last Post: 4th November 2006, 12:23
