Thanks Thanks:  1
Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 201
Thread: URGENT: Everybody who has had issues with injection no.3 on the CDTI engine read this
  1. #21
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by sb1uk View Post
    So what is the actual fault with the no 3 inj.
    SOmething to do with the actual wiring in the plastic plug that plugs onto the injector breaking up..
    Not sure why its only no.3 - I think I remember someone saying that Vx think it may be to do with air flow over that perticular plug.
  2. #22
    Regular Member chris_1d's Avatar
    Cambs
    My engine number is above the number on that message, does that mean my loom should be ok, and that would be unlikely to cause my lack of power below 2k revs, sometimes juddery when cold and idling?
  3. #23
    Regular Member keithsimmo's Avatar
    in the engine compartment.
    Default Fitting instructions?
    Hi can anyone provide me with the fitting instructions or links to a external site on how to fit the "field fix kit p/n 93189918". I have all the above mentioned symptoms and have just bought the kit from the local dealer for just £11.90. Thought it better to try this first rather than what vauxhall suggested changing the air intake pressure vaccum unit (or something similar) for £200+ plus fitting? Error code has been showing p2279. sypmtons are lack of power under 2k and lumpy engine, showing intermitant engine management lights and the spanner light on. Last week it was very similar to driving an old series 3 landrover.
    Thanks in advance.
    Vectra-C 1.9 cdti 150
  4. #24
    Newcastle
    New to this site can anyone help???
    hi,
    Had my vectra 1.9cdti SRI 150bhp a little over 6 months, since weather has been cold I've noticed a slight shudder when started from cold. To cut a long story short I have had the inlet manifold and egr valve replaced 3 days ago (cost £400 to myself as no-one would pay for it) as I was advised this was the problem. Since then car is still the same but I seem to be noticing the shudder when car engine is warm but I'm stopped at traffic lights etc. Had it to vx and they say manifold and egr did need replacing as rod had come off but now they can hear a slight noise on flywheel and the shudder could possibly be a blocked fuel injector and to try STP injector cleaner. I put this in 2 days ago and took it for a good last night but still the same. Garage that done manifold said possibly injectors or turbo but inpeller in turbo ok.
    Anyone got any idea? Starting to pull hair out
    Garage did noy config manifold through computer as said you don't need to could this cause anything?
    How long should I give cleaner to work?
    Please help
    Thanks in advance.
  5. #25
    Newcastle
    Does this sound like injector wiring?
  6. #26
    Northampton
    Engine : A20DTH
    Mileage : 88000
    whats your engine number? Is it before Z19DTH17000444?
    When was your car first registered and what's your mileage?
  7. #27
    Newcastle
    engine number 4259256, registered dec 2004 and 42000 miles
  8. #28
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Well your engine number means that you need the injector wiring mod done then
  9. #29
    Regular Member MattW's Avatar
    Sheffield
    I've just been out and had a look at my 3rd injector, and there is a visible difference between the 3rd and the rest. 1,2 and 4 look good as new, but the 3rd one has what appears to be a green/yellow coating over the plastic plug.
    Worth changing?
  10. #30
    Regular Member WKD-mcc's Avatar
    glenrothes
    does the engine die out at any speed,or is it more likely to happen at a high speed.i think this happened to me last nite
  1. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  2. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  3. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  4. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage2
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage18
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage9
z19dth injektor 3 Pins
vectra injector wires fault common
1.9 cdti Vauxhall signum injector plug
insignia cdti 1.9 injector cable
vectra c 1.9 no 3 injector
1.9 cdti ecotec wiring diagram injectors
vectra c p0201
Z19dth injector wiring fault
z19dt p0201 0f
vectra c injector wiring site:www.vectra-c.com
field remedy 2049
2007 zafira z19dt p0201
vectra c bad injectors connectors
