Thanks Thanks:  1
Page 2 of 21 FirstFirst 123412 ... LastLast
Results 11 to 20 of 201
Thread: URGENT: Everybody who has had issues with injection no.3 on the CDTI engine read this
  1. #11
    Jul 2006
    Friend of mine at work is having identical problems with his 1.9 150. I suggested he give the dealers a nudge in the direction of the injector wiring loom, but apparently there are no problems known to Vx about this....
    He's currently on about his 10th visit back for the same problem, they're trying to fob him off and say that it's not running lumpy, it's just a diesel...
  2. #12
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Quote Originally Posted by parapaul View Post
    Known TIS remedy..
    http://www.vectra-c.com/forum/showth...t=62925&page=4
    print off this and get him to show them
  3. #13
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Print this out and take it in!
    Field Remedy: 2049
    Subject: Engine Z19DT/H - Jerking, somtimes Trouble Code P0201-P0204 set
    Models: Engines: Option:
    Vectra-C 2004...2006,Signum 2004...2006,Astra-H 2004...2006,Zafira-B 2005...2006 Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL,Z19DT| Z19DTH| Z19DTL| Z19DTJ,Z19DT| Z19DTH| Z19DTL
    Complaint: Customer complaint about jerking sometimes SVS lamp on and DTC P0201-P0204 set.
    Cause: Software and / or fretting corrosion on injector plug.
    Production: Modified wiring harness has been implemeted in production as of engine numer: Z19DTH17000444.
    Remedy:
    In case of customer complaint reprogram ECU according TSB 1849 before changing any parts.
    If TSB 1849 will not cure the problem install field fix injector plugs (partnumber 93189918 / cataloguenumber 62 86 769).
    Mentioned Field fix kit does not contain of a 1,5mm² wire as mentioned in TIS 2000 wiring diagram.
    In case of concern please use 2,5mm² instead.
    FunctionalGroup: J - Engine
    Complaint Group: 06 - Failure Code Setting by Control Unit
    Trouble Code: P0201,P0202,P203,P204
  4. #14
    kings lynn
    can anyone help me , i have a 56 plate sri 150 cdti when i start tha car in the mornings from cold it smokes like an old cortina and runs very lumpy for about a minute then clears . It has been to VX several times and they say theres nothing wrong with it . I should also say it has had 2 injectors a manifold and swirl pot done about a year ago. I am getting very frustrated about the problem and VX dont seem very interested .
  5. #15
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by satfat2506 View Post
    See the post above yours and get the work done and see if it solves your problem. If it cures it and you reported the fault when you car was under warranty you would have a case for a claim against VX for the cost even. Is yours still under warranty?
  6. #16
    norfolk
    Hi everyone,this is my first ever post.
    Just had inlet manifold done due to e/m light and spanner,out of warranty 50%paid by vx,ok for one day then same identical faults leading to limp home mode again,back to dealer diagnosed as no3 injector connnector so in my mind did not need manifold,looked at swirl valves on old unit and look perfect.Car currently at dealers waiting for all injector connections to be replaced asked for money back on manifold job as mis diagnosed,they refused....I will take it further
  7. #17
    Bristol
    Default no 3
    Where can I get the new wires from.
  8. #18
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by sb1uk View Post
    Might we worth trying the local stealer
  9. #19
    norfolk
    Default update
    Hi just got mine back from dealer,replaced wiring and plugs to all four injectors,looks a tidy job on the surface but god only knows how they joined it to the main loom!!Dealer still will not refund cost of manifold job but did not charge for this fix and offered big discount on cam belt replacement next service.Did find one engine cover rubber missing,hose not put on correctly and a broken clip for wiring.They are going to remedy these as well.Only done 6miles so far so can only hope its finally fixed for good.
  10. #20
    Bristol
    Default fault
    So what is the actual fault with the no 3 inj.
  1. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  2. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  3. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  4. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage2
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage18
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage9
z19dth injektor 3 Pins
vectra injector wires fault common
1.9 cdti Vauxhall signum injector plug
insignia cdti 1.9 injector cable
vectra c 1.9 no 3 injector
1.9 cdti ecotec wiring diagram injectors
vectra c p0201
Z19dth injector wiring fault
z19dt p0201 0f
vectra c injector wiring site:www.vectra-c.com
field remedy 2049
2007 zafira z19dt p0201
vectra c bad injectors connectors
