Thanks Thanks:  1
Page 1 of 21 12311 ... LastLast
Results 1 to 10 of 201
Thread: URGENT: Everybody who has had issues with injection no.3 on the CDTI engine read this
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default URGENT: Everybody who has had issues with injection no.3 on the CDTI engine read this
    Hi all,
    this is very important!
    I have had the known issue with injector no 3 on the CDTI engine.
    It caused my engine to shut down while driving at 70 mph on the motorway. After getting the fault repaired at VX I have since emailed VX Customer Services regarding the issue and the fact that the engine shuts down while driving. They seem to not care about this and have basically told me to go away. I believe that this should have been a recall and the modification required carried out free of charge.
    So I have contacted VOSA and started the ball rolling. They are very interested in this and need me to help get further evidence of the engine shutting down or where the fault has caused a safety issue, ie loss of power while driving etc.
    This fault has been known about by VX for 3 years or so. They have no excuse!
    I was just glad that I was the only one in the car and the M1 was not busy when my shutdown happened.
    So guys please add your comments below
    Regular Member spatch's Avatar
    Aug 2007
    Kent
    Doesn't sound good. What exactly happens then, and what is the cause (was not aware of a no. 3 injector issue on the 3.0CDTi).
    I would have thought that it should go into some sort of limp home mode, if it just shuts the engine off then that could be very dangerous.
    Let us know how you get on as I do not like the idea of mine just turning itself off with the family in it.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Sorry, should gave said this only applies to the 1.9CDTi 120/150 engine
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Now have form to fill out from VOSA
    Does anyone else need a copy of this?
    Please let me know if you have suffered the same issue!
    Aug 2007
    Kent
    Quote Originally Posted by merikiito View Post
    Fair enough, good luck with it.
    wigan
    i think i've heard of this, isn't it the wiring connector where it plugs it get clogged up? hope doesn't happen to me !!!
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    I get intermitant lumpy idling which is almost like it is running on three but I havnt looked into it or know what it is
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by ANDY W View Post
    Yep it is the same issue, beware as the engine can just cut out while driving! Get it sorted ASAP
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Just had mine done fella at the stealers... Invoice to prove if needed.
    Happy to log it also, bad judder and lack of power when cold for me... totally changed now its fixed
    Administrator plasma's Avatar
    On the Forum
    545 Post(s)
    Engine : 150
    Mileage : 74000
    I had this happen to me whilst doing a high speed run on the autobahn in germany a cpl of years ago, not fun going from 130ish down to 40mph uphill! Did a temp repair as i found out what the fault was and it last me till i got home'ish, this was before it was a well known issue.
    Lee, I can help out if you want me to fill out one of them forms mate.
  1. V6 CDTI engine issues
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2012, 10:18
  2. 1.8 VVT Engine Issues!!!
    By SteB13 in forum Engine & Drivetrain
    Last Post: 7th June 2010, 17:39
  3. Engine Issues? 1.9 CDTi
    By Ean in forum Engine & Drivetrain
    Last Post: 14th April 2009, 19:25
  4. engine issues
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2007, 22:09
vectra c bad injectors connectors
vectra injector wires fault common
1.9 cdti Vauxhall signum injector plug
https:www.vectra-c.comforumshowthread.php63811-URGENT-Everybody-who-has-had-issues-with-injection-no-3-on-the-CDTI-engine-read-thispage18
insignia cdti 1.9 injector cable
vectra c 1.9 no 3 injector
1.9 cdti ecotec wiring diagram injectors
vectra c p0201
Z19dth injector wiring fault
z19dt p0201 0f
vectra c injector wiring site:www.vectra-c.com
field remedy 2049
2007 zafira z19dt p0201
z19dth injektor 3 Pins
