Results 1 to 10 of 27
Thread: Egr valve - expense?
    Regular Member MRLUBBERLUBBER's Avatar
    North Lincs
    Default Egr valve - expense?
    My Signum was chucking a loada smoke out from the engine compartment last night BUT no warning lights on the dash and running sweet as a nut. My mate who owns a garage is taking a look at it later but from what i've described to him he reckons it could well be the EGR valve, apparently a common fault on Signums and Vectras. Big job is it and what sort of expense am i looking at IF its the EGR valve? Anyone any ideas please? Thanks.
    North Lincs
    Just to add, there's no black smoke chucking out of the exhaust.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Its free to remove it and clean it (how2's on the site) and is recommended to do that before buying a new one.
    North Lincs
    I didn't know you could do that but thanks for the advice blacksri
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by MRLUBBERLUBBER View Post
    This thread shows how to do it, and has good pictures also..
    Regular Member morbid movie's Avatar
    wrexham
    Vehicle : insinia
    Trim : srinav
    Engine : 160cdti
    Year : 2011
    Mileage : 11,350
    a lot of v6 vec b's have had the egr blanked off and gives better performance alledgedly
    not sure about the signum but the engines should be similar
    someone else may come along with a different response
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by morbid movie View Post
    I did that on my B, but you can't do that on the Vec C's (CDTi''s) as the ECU will chuck a benny.
    wrexham
    Vehicle : insinia
    Trim : srinav
    Engine : 160cdti
    Year : 2011
    Mileage : 11,350
    thanks for that just wondering
    the self clean seems a cheap easy option anyway better than being ripped off at the stealers
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Split turbo hose if the smoke was coming from the engine bay although that might have an effect on performance. Not sure how the EGR valve would cause smoke as its sealed is it not? I took mine apart the other week to check and it was fine but then I was doing high mileage motorway driving which helps keep it clean.
    I think my money would be on a split hose, so check them first
    also I remember my girlfriends car doing this as well now and again. She had a 120 CDTI Vectra C Estate with the DPF thingy which is also on the Signum. I think when this regenrated there was the odd bit off smoke. Could be wrong tho
    North Lincs
    Thanks a lot for the advice/tips etc lads. I've left the car at the garage for further investigation. Bloke there reckons best case scenario is busted turbo gasket, worst case scenario the EGR valve. Quick note; the car was left ticking over for 20 mins in the garage, no fault codes, no black smoke coming from the exhausts, sounded perfect. Mechanic got lad in the car to floor it for a couple of secs, we saw a cloud of white smoke coming from the turbo or just below the turbo area, he repeated this and it did it again.
  1. Today's expense
    By mattspear in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2012, 13:22
  2. Have a laugh at Manchesters expense...........
    By merikiito in forum Comedy & Humour
    Last Post: 8th December 2011, 13:47
  3. A non Vectra expense
    By silverhairedracer in forum General Chat
    Last Post: 3rd August 2009, 07:17
  4. more expense on my car
    By solorider in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2009, 12:00
  5. More Expense
    By phil67 in forum The 'Off Topic' room
    Last Post: 26th August 2008, 12:34
