Page 6 of 6 FirstFirst ... 456
Results 51 to 58 of 58
Thread: Washers stopped working
  1. #51
    Regular Member Marc 100's Avatar
    Nov 2005
    Berks
    Hi all, the washers on my car have given up. Pump is buzzing and there's just a trickle so presume reservoir and pump filter need a clean.
    I've located the two torx screws on the wheel liner but cannot find the third that everyone mentions under the car. Where is it roughly?
    I'm also guessing this job would be easier with the wheel off and the car jacked up, or is that not strictly necessary?
    Thanks.
  2. #52
    Worcs/Staffs/Westmids (ish)
    You put the water in the right hole... yes?
  3. #53
    Regular Member old cruiser's Avatar
    slough
    Quote Originally Posted by Marc 100 View Post
    Thanks.
    To be honest mate it's not really necessary to remove wheel , just start the car up and turn steering to full right lock, with the torx screws removed you can pull the liner out enough (a bit fiddly) to get to the pump, at least that's what I did earlier this year; there should be 3 Torx screws there on the liner, i.e the lower one which is about an inch or so from the edge of the bumper as it were and then the other two are up from that, maybe you have one missing? HTH
    Cheers Pete
  4. #54
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Trim : Club
    Engine : Y20DTH
    Mileage : 79k
    i had mine pack up on me a few weeks ago i put a pin in holes and all storted, but i noticed when i was fitting my hod when i took the long neck off the tank there was a blob of green muck flotting in the tank some how i need to get it out,
  5. #55
    Oct 2007
    Shropshire
    Mine work fine (or they did) but I haven't had any water in them since I started uni!!!!
  6. #56
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Have you simply tried pushing a hosepipe down the filler neck and turning on full and letting it overflow for a while? It certainly gets rid of a lot of crud etc.
    Simple, quick and easy.
    Non working washers is a MOT failure and the Police don't like it either !
  7. #57
    Nov 2005
    Berks
    Thanks for the replies.
    "Have you simply tried pushing a hosepipe down the filler neck and turning on full and letting it overflow for a while? It certainly gets rid of a lot of crud etc."
    Yes, tried both blasting with the hose and putting hot water in several times, leaving and then siphoning out but still no good. It's bound to be the filter, the car's 6 years old after all.
    Like I said I've removed the 2 visible torx screws (twice now) from the liner, pulled it back as far as it will go and can see the pump. The liner does feel like it will break unless I remove a third screw somewhere else in order to get my hand in to pull the pump and filter off. Had a crawl round underneath and couldn't see any further attachments. Will look for a third torx in the liner itself as Pete suggests.
  8. #58
    Regular Member davemiracleman's Avatar
    Nov 2007
    Felixstowe
    Nice one BigP....my problem was the Elbow piece/one way valve.
    Now taken it out and plugged the pipe direct to the pump until i can get a new one.
    Thanx
  1. Right my hid stopped working
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 15:22
  2. Windscreen washers stopped working
    By tomo41 in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2011, 18:10
  3. DAB stopped working
    By sandman1001 in forum Electrical & ICE (including SatNav)
    Last Post: 8th February 2011, 22:27
  4. Strange one! Washers stopped working but not totally
    By v6vc in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd January 2010, 21:20
  5. Fan stopped working
    By andyxedos in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 23:18
