Results 1 to 10 of 25
Thread: New HID's
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    Default New HID's
    Well after a lot of consideration (at lest 30 seconds) i decided to order myself a set of 50w 4.3k HID's from HID direct. They come complete with the bulb failure wires, bulb holders and a set of side light bulbs for £91 delivered!!!! Result hope i'm as impressed when they arrive!
    Northampton, UK
    Quote Originally Posted by sdemps View Post
    I've just received mine, arrived day after I paid! Mine are the 6k bulbs tho, I'm just looking around the wings now to see where the ballast pack and cancellers are going to go! Gulp...
    Anyone here got any pics of where they bolted their packs???
    One for you mate - You'll probably need to go and buy a 25mm hole cutter, it says you need one to drill a hole in the access cap to push the wires through.
    Nov 2007
    Ayrshire
    I'm sure i've got a pack of cutters somewhere. Mine arrive on Monday, luckily i'm off tuesday so guess what i'll be doing ha!! Hope you get yours all sorted out, give me a wee shout and let me know how they are?
    Belfast
    50W? Are they brighter than the standard 35W ones?
    I was looking at an MTEC kit with the 5100K GE bulbs, as I'm driving about with 1 HID and 1 normal bulb since one of my elcheapo blew up last week. £149 though.
    Belfast
    Just had a look at the 50W jobs - 8A start current? Hmm...do they come with a relay or can the Vectra's lighting unit run that OK?
    Regular Member G.T.S's Avatar
    Helsinki
    I had a set of 55W in my headlights and those did not work so now a have 35W in driving lights and 55W in the other ones(dont now the english name?) and looking to have one set to the fog lights but i would recomned the 6000K they look more nice
    Maida Vale
    Quote Originally Posted by n_hudson View Post
    On my wife's prefacelift I placed the ballast box inside the battery cover on the nearside (lots of space in there, so it was well away from the battery - althought I don't know if diesel models have bigger batteries..?) and on the offside I stuck it just tucked under the edge of the wing (accessible after removing the airbox).
    Nov 2007
    Ayrshire
    I looked into it and 55w ones are meant to be almost twice as bright again as the 35w ones. We'll see soon enough i suppose. 8amp start up? It'll be fine it'll be at least a 10amp fuse on the circuit and the wiring will handle double that!!!
    Nov 2007
    Ayrshire
    Well i got my hid kit in...... Not best pleased! After putting it all together one refused to work, turns out one of the warning cancellors isn't working (not a great start) got both of them working and took it a run. Got two dark patches running through the center of the beam pattern WTF!!!! Looked at the box to see if i'd done something silly and it turns out it's a 35w kit too!!!! Bulbs fitted correctly, i'll be on the phone tomorrow and see whats happened. Has anyone else had a dark patch in they're beam pattern before?
    Reading
    The dark line in the beam is the electrode that runs along the outside of the bulb, I turned mine round so the electrode runs across the top of the bulb when its in the light, the bulb retaining clips are then very tight, but with a bit of persuasion they do go in, my kit was 60 quid plus postage with a 2 year warranty, been in about a fortnight now, and no problems as yet, well impressed with the difference between the HID and the standard halogens.
  1. HID's
    By disco dan in forum Styling
    Last Post: 11th June 2011, 23:59
  2. hid's
    By G4GAV in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2011, 18:42
  3. best HID's
    By paul_sri150 in forum Vectra C / Signum Car Chat
    Last Post: 26th October 2010, 10:16
  4. HID's
    By Daywalker in forum Styling
    Last Post: 15th November 2009, 18:20
  5. HID's
    By david.91.09 in forum Styling
    Last Post: 24th October 2009, 18:28
