Results 1 to 10 of 23
Thread: 3.0 v6 cdti turbo problem
    Liverpool
    Default 3.0 v6 cdti turbo problem
    My 2004 3.0 cdti sri has developed a whirring noise and has since got worse, understand it could be a number of things but most likely the turbo??
    I will get this double checked before any work but i have found a second hand turbo on a 2006 model, can these be fitted to my 2004 without any fuss? There after £195+vat with a 90 day warranty, presume reconditioning or a new one is alot more!
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    Quote Originally Posted by chrisd View Post
    I know it's a petrol but Duncan had his 2.0T reconditioned. he tookl it off sent it away came back fixed.
    Liverpool
    Thought reconditioning would cost more than the second hand one am looking at?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    a 2006 turbo is different .....check your air filter is it blocked ..? ....
    Quote Originally Posted by willc01 View Post
    Yep - sent mine to Turbo Technics when the wastgate disc came detached. Worth a call to them to see if they deal with that particular turbo. They may not do reconditioned units as such of that model, but they should still be able to fix any issues with it and then rebalance it. It may cost a bit more than a second hand one, but you'll be getting it rebalanced to a tolerance far higher than when it came out of the factory!, and if it has a bearing and seal service (if needed) then it'll be practically as good as new - almost. The second hand one you may get could end up packing in after a few months - you just don't know. Do you know how many miles the second hand one has on it?
    Before you start thinking about replacing/removing turbos you really need to be sure that it's the turbo at fault.
    Liverpool
    Quote Originally Posted by benny View Post
    Will drop by my local garage to rule out anything simple before i do any work, but having read the related posts on here am quite sure its the turbo, have checked the filter box and connecting pipes aren't blocked.
    The 2006 donar car had done 16k but if the turbo is different i best look else where!
    Whats the typical price for turbo-technics fixing this turbo and whats the worst case it could be??
    Liverpool
    [quote=chrisd;750833]
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    I recently contacted Turbo Technics as I has an issue with Vanes sticking in the turbo and it was going to cost 175 + VAT to be done or 245 + VAT for bearing and seal done too. Although they won't be able to give an exact price until they know exactly what is wrong with it. (they have tested it).
    Fantastic company with a very good rep.
    Bri.
    Liverpool
    Just got the latest from the garage, 'checked it front and back and theres play in it, 99% needs a new turbo' ?
    Part only from vaux is £1200+VAT and my garage wants 6 hours to fit!!!!!
    Can these turbos be reconditioned, garage advised this type of turbo has a bad history when repaired and even said he wouldnt want to fit it unless it was new.
    Is it even worth shopping round for a second hand one, these are rare and the chances of a finding a relativley good one must be close to nil.
    Any ideas on how i can solve this or save on the repairs??
    2004 Vectra 3.0 CDTI.
    How much for a turbo?!!!
    Give Turbo Technics a ring. They reconditioned my turbo in my 2.0T when it had a glitch in it (wastegate disc on the inside came off).
    AFAIK it's a Garret turbo in yours as well, and whilst they will deal with a number of makes they specialise in Garrets. If they deal with the model you have, they'll be reconditioned and rebalanced to a finer tolerance than when they came out of the factory!
    I think the line about repaired ones having a bad history is just that - a line to get you to buy a new one.
  1. 2.2 dti Turbo problem
    By Shortland78 in forum Engine & Drivetrain
    Last Post: 18th February 2011, 14:34
  2. vectra 150 cdti....turbo problem?
    By trigger in forum Engine & Drivetrain
    Last Post: 29th May 2009, 14:53
  3. Turbo Problem
    By sberrow in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2009, 21:01
  4. 3.0 CDTi Turbo problem (s)
    By beepee in forum Engine & Drivetrain
    Last Post: 5th February 2009, 15:23
  5. 2.0 DTI turbo problem
    By Vibez_Uk in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2008, 21:15
https:www.vectra-c.comforumshowthread.php63773-3-0-v6-cdti-turbo-problem
v6 cdti turbo issue
opel vectra c 3.0 v6 cdti turbo
opel signum 3.0 v6 cdti 2008 nejÄastÄ›jší problem
opel signum 2003 3.0 v6 cdti problems
3.0 cdti start badly
opel signum 3.0 v6 cdti problemy
turbo for 2006 vectra c 3.0 v6
Does a vectra 3.0 v6 cdti have a turbo
vectra c 3.0 v6 cdti turbo nozzle ring problem
