Results 1 to 10 of 11
Thread: cruise control fault
    glasgow
    Default cruise control fault
    my cruise control on my vectra dont work at all ,its worked once since i got the car but once only i dont even get the green light on the dash when i try activating it any ideas pls
    52 plate 1.8 petrol
    model/ ellegence
    Blantyre
    Quote Originally Posted by alexgrfc View Post
    52 plate 1.8 petrol
    model/ ellegence
    Place your foot under the brake pedal and jerk it up, and also the clutch (one at a time ), maybe one or the other is not raising completely to the top, or could be a switch prob
    Had this issue 2 weeks ago but only did it once , so i did the above and been fine since
    Sep 2007
    Thornton Dale
    Vehicle : Transit Custom
    Trim : Limited
    Engine : 125PS
    Year : 2013
    You can buy a spring for a fiver that goes under the clucth pedal that keeps the pedal at its highest point.
    As the clutch gets used over time, the spring weakens or snaps and the pedal drops which makes the switch for the cruise not work correctly.
    Takes less than 5 minutes to fit.
    Aug 2006
    Is a very naughty boy
    Don't forget you need to have pressed the preak pedal once on your trip before it will work too
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    P is a long way from the B on the keyboard.
    PS When did you become a Guru??
    Regular Member steeb82's Avatar
    darlington
    i have exactly the same car and have the same issue
    Northampton
    Engine : A20DTH
    Mileage : 88000
    The cause of this is a broken spring under the clutch pedal or which ever one it is. Its a known VX fault and there is a modified part which only takes a couple of minutes to fit and costs £6-7. Happened on my Vectra C 1.8 SRi when I had it.
    darlington
    were can i get part and what needs to be done??
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by steeb82 View Post
    I would try the dealer first, probably a Vauxhall one
    Talk to them nicely and they may even fit it for you for free, mine did!
    Have u checked for a broken spring?
    Oxfordshire
    13 Post(s)
    Vehicle : Vauxhall Astra-J
    Engine : 2.0 CDTi
    Year : 2013
    One quick forum search:-
    http://www.vectra-c.com/forum/showthread.php?t=33621
  1. cruise control fault, new stalk fix problem?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 21st July 2013, 11:16
  2. Cruise Control Fault.
    By pattz123 in forum Bodywork & Interior
    Last Post: 7th February 2011, 00:24
  3. vectra c cruise control fault
    By hopkinson06 in forum General Chat
    Last Post: 31st January 2009, 14:42
  4. Cruise control fault?
    By jamesr in forum Engine & Drivetrain
    Last Post: 10th May 2008, 11:00
  5. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
